Page 1 of 6
Spacers fitted.
Posted: Tue Mar 15, 2016 7:54 pm
by mjwebb48
Got home from work early so thought I'd do something useful!
12mm front and 15 rear.
Got kW adj Spring kit in the garage but actually quite happy with the stance.
Perfect size for anyone looking at it.
Mat
Re: Spacers fitted.
Posted: Tue Mar 15, 2016 9:03 pm
by robf
Looks good, but any reason why the 3mm difference front to rear? Did you do some measurements to calculate they would be the ideal size?
Re: Spacers fitted.
Posted: Tue Mar 15, 2016 9:08 pm
by mjwebb48
What was recommended and to be fair it's spot on. Big old rear arches on them!!
Re: Spacers fitted.
Posted: Tue Mar 15, 2016 9:12 pm
by MikeFish
Rob, mine looks like it has more clearance on the rear wheels than the front, same as the B7. It is a bit harder to tell on mine as the front is lower but I think it looked like there was more space on the rear before I lowered it.
Re: Spacers fitted.
Posted: Tue Mar 15, 2016 10:35 pm
by toshers
24mm on the front and 30mm on the rear axle is a lot :shock:
More space there than I thought. Will this not cause the tyres to scrub out quicker?
Re: Spacers fitted.
Posted: Tue Mar 15, 2016 10:42 pm
by Andy_W
Looks good. Which make spacers did you get? Any more side on photos?
Re: Spacers fitted.
Posted: Tue Mar 15, 2016 11:04 pm
by mjwebb48
Eibach with longer bolts from revolution.
Re: Spacers fitted.
Posted: Tue Mar 15, 2016 11:39 pm
by Andy_W
mjwebb48 wrote:Image
Oooh that does look good! Any different feel driving? I was thinking 12 all round but 15 at the back seems to work well.
Re: Spacers fitted.
Posted: Tue Mar 15, 2016 11:55 pm
by mjwebb48
Not driven yet as I've got a tire that needs replacing. Bulge in sidewall!! 1800 miles!!
New one going on at weekend so I will let you know. Wouldn't have thought it will be noticeable.
15mm def works at rear.
Re: Spacers fitted.
Posted: Sat Mar 19, 2016 7:20 pm
by RS6chris!
Any chance of a link to where You got them?
Ta.
Re: Spacers fitted.
Posted: Sat Mar 19, 2016 7:58 pm
by MikeFish
I think he bought them from another member on here. But Revolution or Virdee are good for the right type of fitments.
Re: Spacers fitted.
Posted: Sat Mar 19, 2016 8:07 pm
by RS6chris!
MikeFish wrote:I think he bought them from another member on here. But Revolution or Virdee are good for the right type of fitments.
Virdee tells me he can't source them?....il try Revolution.
Re: Spacers fitted.
Posted: Sat Mar 19, 2016 8:20 pm
by MikeFish
Pretty sure Virdee did me a quote a couple of months ago. He even checked he could get them in black to match the wheels I was looking at. Maybe he tried ordering since and they couldn't get them. You tried Glenn at Revolution?
Re: Spacers fitted.
Posted: Sun Mar 20, 2016 1:08 am
by mjwebb48
Verdi said same to me. I had rears but sourced fronts from little glen at Revolution , just drop them a pm. Also got longer bolts and longer locking wheel nuts as well.
Re: Spacers fitted.
Posted: Sun Mar 20, 2016 8:08 am
by RS6chris!
mjwebb48 wrote:Verdi said same to me. I had rears but sourced fronts from little glen at Revolution , just drop them a pm. Also got longer bolts and longer locking wheel nuts as well.
Thanks fella
Are you DRC or air?
