Page 1 of 2
European Sat Nav Map?
Posted: Sat Jan 02, 2016 2:43 pm
by MikeFish
Does the C7 come with sat nav maps covering all of Europe? In particular I'm interested in France, Belgium, Holland & Germany. I can't seem to find this info anywhere.
I have a wedding in dusseldorf in May and am thinking it might be a nice little road trip.
Posted: Sat Jan 02, 2016 3:46 pm
by Moonmonkey831
Pretty sure it will. I've driven to France in my rs4 and all was there, so the c7 must as a newer tech. Have you tried planning a route and zooming into the destination to confirm?
Re: European Sat Nav Map?
Posted: Sat Jan 02, 2016 4:29 pm
by asifg
If it doesn't use Navmii for free SatNav from your mobile, or if you have a good data roaming deal with your network, use Waze. I have Built-in Nav on both of my cars but only ever use Waze
Posted: Sat Jan 02, 2016 4:39 pm
by MikeFish
Moonmonkey831 wrote:Pretty sure it will. I've driven to France in my rs4 and all was there, so the c7 must as a newer tech. Have you tried planning a route and zooming into the destination to confirm?
Thanks, not taken delivery yet so can't check for now.
Posted: Sat Jan 02, 2016 4:40 pm
by MikeFish
asifg wrote:If it doesn't use Navmii for free SatNav from your mobile, or if you have a good data roaming deal with your network, use Waze. I have Built-in Nav on both of my cars but only ever use Waze
Thanks but I'd rather use the built in nav if I can. Can you use Google Maps via connect even if you don't have the map on the HDD?
Or alternatively I'll buy the appropriate map.
Posted: Sat Jan 02, 2016 4:42 pm
by Moonmonkey831
Ahh fair enough! I'd be 99.9% sure you'll be fine
Posted: Sat Jan 02, 2016 4:50 pm
by HYFR
Yes it does
Posted: Sat Jan 02, 2016 5:21 pm
by MikeFish
Ok thanks Dave.
Posted: Sun Jan 03, 2016 11:52 pm
by Heden
Just came back after driving through all those countries, and I can confirm that the Sat Nav have full coverage.
Posted: Mon Jan 04, 2016 12:04 am
by MikeFish
Thanks. Any special tips eg which countries require special equipment like high vis vests etc?
Did the headlights automatically adjust to driving on the left or did you have to manually set it through the MMI?
Posted: Mon Jan 04, 2016 11:53 pm
by Heden
MikeFish wrote:Thanks. Any special tips eg which countries require special equipment like high vis vests etc?
France requires you to have high vis vest and breathalysers, so I recommend having those in the car at all times.
The headlights changes automatically based on the country the car is in (takes it from the sat nav). It works a treat and the LED Matrix is awesome :kissmyrings:
Posted: Tue Jan 05, 2016 12:28 am
by MikeFish
Thanks Heden
Posted: Tue Jan 05, 2016 9:06 am
by wildbore
And the high-vis jackets MUST be accessible from the driver's seat. Putting them in the boot is not acceptable. I expect it's only the must curmudgeonly of Gendarme's who would have you on this technicality, though.
Posted: Tue Jan 05, 2016 9:30 am
by MikeFish
Thanks. I found a nice guide to each of the countries on the AA website which explains all the little bits I need to know. It says exactly what you said that the hi-vis needs to be in the car not the boot so you can wear it before you get out of the car in the event of a breakdown. And about the breathalysers etc.
Posted: Tue Jan 05, 2016 9:45 am
by wildbore
Those high-vis jackets are not just for breakdowns. When the Clifford BlackJack kicks in, the criminals can make safe and orderly exit from the vehicle wearing high vis jackets to ensure they can be seen by other road users whilst they deploy the emergency warning triangle.
