Radiator fan staying on
Posted: Mon Nov 16, 2015 6:08 pm
by Powerenhancer
Anyone notice the engine fan staying on after shutdown? Happens with my 14 plate after every journey. Also, noticed the start/stop function has never kicked in yet.
Re: Radiator fan staying on
Posted: Mon Nov 16, 2015 6:16 pm
by wildbore
Yes, the fan runs on even after the most modest drive involving minimal revs.
My start-stop is the opposite - it sometimes cuts in after less than a mile of driving, despite one of the pre-conditions being that the engine is supposed to be warm.
Posted: Mon Nov 16, 2015 6:29 pm
by Eddie555
RE the start stop. Are you using your hill hold assist function?? I:e pulling up to a stop and lifting off your brakes and letting the ebrake take control. You must leave your foot firmly pressed on the foot brake whilst you come to a stop. The split second you lift your foot it'll cancel the feature. Oh yea the engine needs to be warm as well.
Posted: Mon Nov 16, 2015 7:13 pm
by Powerenhancer
Don't use hill hold assist. Brake on firmly but get a crossed A every time. Always worked on previous Audi's unless the engine was cold or the aircon on full blast. Tried in D and N.
Posted: Mon Nov 16, 2015 8:07 pm
by Eddie555
Powerenhancer wrote:Don't use hill hold assist. Brake on firmly but get a crossed A every time. Always worked on previous Audi's unless the engine was cold or the aircon on full blast. Tried in D and N.
Crossed A means it's not ready. I've also noticed it doesn't work when the heated rear screen and or the heated seats are on.
Posted: Mon Nov 16, 2015 9:09 pm
by Powerenhancer
The problem is that the system is never ready even with all those switched off.
Posted: Mon Nov 16, 2015 9:15 pm
by Eddie555
Dunno then. I'm not sure if it can be turned off via VCDS but I'm sure someone on here maybe able to clarify.
Posted: Mon Nov 16, 2015 9:18 pm
by Markp
Are you in dynamic engine and transmission setting (or S by pulling stick back)?
Posted: Mon Nov 16, 2015 10:03 pm
by Powerenhancer
Auto in engine/trans for 95% of the time. Very strange, I thought it may be to do with a fault keeping the aux fan on all of the time and needing the battery power, hence having to keep the engine running.
Posted: Mon Nov 16, 2015 10:12 pm
by Markp
Check your efficiency programme on the computer to see what's running. Should list anything pulling power.
Posted: Tue Nov 17, 2015 12:13 am
by RSphantom
Fan staying on after driving is normal, mine does it for up to 10mins after driving. Re stop/start. How long have you had the car? If you have only just got it then it may take a few days as it might have been sat around for a while :beerchug:
Posted: Tue Nov 17, 2015 2:05 pm
by Powerenhancer
Checked the efficiency program today and only have a very small green bar when the heater is on (no aircon). Turned the heater off to reduce consumption to zero and the stop/start kicked in for the first time. It will only work with the heater completely off so maybe a weak battery?
Posted: Tue Nov 17, 2015 6:15 pm
by RSphantom
Powerenhancer wrote:Checked the efficiency program today and only have a very small green bar when the heater is on (no aircon). Turned the heater off to reduce consumption to zero and the stop/start kicked in for the first time. It will only work with the heater completely off so maybe a weak battery?
Could be a weak battery. Do you do short journeys? I only ask as when I got mine the stop/start didn't work properly until I had taken it on a decent run about a week after I got it. I did 100 mile round trip and after that its worked fine.
Posted: Wed Nov 18, 2015 5:20 am
by koruki
Totally normal but know why you're concerned, test car was doing it and I thought I had left it on. The car regenerates power on braking, I wonder if there is a separate battery that runs the fans after shut down from the regenerated power?
