Page 1 of 2
Steering Wheel fail
Posted: Thu Mar 26, 2015 10:54 pm
by PSB1
Re: Steering Wheel fail
Posted: Thu Mar 26, 2015 11:11 pm
by markwm
How do you end up with that wheel when it's not even on the options list?
Posted: Fri Mar 27, 2015 12:02 am
by RSphantom
It used to be an option on pre facelift cars, heated as well if I remember correctly. It's does have ceramics to make up for it. Quite a bit of car for the money.
Posted: Fri Mar 27, 2015 12:03 am
by ollys
but lovely car - Misano with carbon is ace combo and it has ceramics - I could live with that wheel...
Posted: Fri Mar 27, 2015 12:14 am
by markwm
RSphantom wrote:It used to be an option on pre facelift cars, heated as well if I remember correctly. It's does have ceramics to make up for it. Quite a bit of car for the money.
Yea, 9 months old, 2.5k miles, list price must have been pushing £100k. Big drop.
Posted: Fri Mar 27, 2015 7:15 am
by PSB1
Yeah, otherwise it's been well specced. How much of a ball ache is it to replace it with the appropriate wheel?
Posted: Fri Mar 27, 2015 7:19 am
by smudge
Did the pre fl cars have that gear leaver too? I spot it's an 'OE' reg car, so I wonder if it has something to do with being one of those press cars that has options you can't physically choose from the config, but are added by the factory to show their functions.
Posted: Fri Mar 27, 2015 8:27 am
by doodlebug
Yes, there was another gear lever option, though can't recall what, have a brochure somewhere.
1 owner, many drivers.
Posted: Fri Mar 27, 2015 9:10 am
by wildbore
I know this opinion will find little sympathy here, but....
That wheel has one major thing going for it. It's round. Frankly, I find twirling the RS6 wheel around in a car park a real annoyance. The flat bottom serves no real purpose as the RS6 is not a racing car. All that happens is the wheel rim is 'in the wrong' position as you feed the wheel through during tight maneouvres. I find flat-bottomed wheels on road cars an affectation and more than a little pretentious. Even a mini roundabout takes your hands into flat-bottom territory as the steering ratio is quite high (as you would expect on a road car).
Posted: Fri Mar 27, 2015 11:11 am
by Lewy
I'm with you Wildbore...
Flatbottomed wheel looks great, but I do find it a bit of a pain in tight spots... I much preferred the round wheel in my A6 TDI.
The Walton Audi RS6, looks a great car none-the-less. Would it put off potential buyers without the flat bottom wheel? Not me.
Lewy
Posted: Fri Mar 27, 2015 11:47 am
by bam_bam
That wheel is a travesty.
You're correct, zero sympathy. At no point should you need to handle the flat part of the wheel.
Posted: Fri Mar 27, 2015 11:53 am
by wildbore
bam_bam wrote:... At no point should you need to handle the flat part of the wheel.
?? How can you not need to use a whole quarter of the wheel's circumference when maneouvring into parking spaces and doing three-point turns?
Posted: Fri Mar 27, 2015 11:59 am
by bam_bam
Errrm, you turn the wheel until your arms near cross-over, the 'top' arm always has 'right of way' and the 'bottom' arm comes off placing the hand back at the same position. Rinse. Repeat. Have you ever had track tuition?
Posted: Fri Mar 27, 2015 12:05 pm
by wildbore
bam_bam wrote:Errrm, you turn the wheel until your arms near cross-over, the 'top' arm always has 'right of way' and the 'bottom' arm comes off placing the hand back at the same position. Rinse. Repeat. Have you ever had track tuition?
What has track tuition got to do with parking the car in Sainsbury's car park?
And yes, I have.
Clearly Audi fitted a flat-bottomed wheel to pander to the fantastical world that you create for yourself every time you get in your car. Vroom! Vroom!
Posted: Fri Mar 27, 2015 12:11 pm
by bam_bam
Ha, Sainsbury's! Clearly.
Now now, calm down and count to potato. Soooo, I tell you that is no reason that you'd need to touch the flat-bottom part of the wheel, you ask how, I explain how AND now I'm the <beep>?!
Cool. Vroom! Vroom!
