Sports exhaust query
uplandsway
Post by uplandsway » Mon Jul 29, 2019 1:08 pm
jamesbilluk wrote:Hi guys
Whilst cleaning the exhausts thismorning, I noticed valves in the exhaust, does the standard system have them? They were closed before I went out, now open when I returned from a drive
James
Hi
First thing I’d be doing is soaking the flaps in wd40, just spray it inside the tailpipe
Make sure your valve plugs are properly connected too
If you run the car on drive and press drive select you should hear the solenoid firing when you go into dynamic and so on
(Looks like you need some black exhaust tips too lol..I have some for you freshly painted in black)
Cheers,
Stevie F
2016 C7.5 RS6 Performance
jamesbilluk
Re: Sports exhaust query
Post by jamesbilluk » Mon Jul 29, 2019 1:38 pm
Many thanks, will give that a go :)
Didn't know that the standard system has valves too,
James
2013 C7 RS6 (in a shade of red I'm still trying to identify..)
Lig
Post by Lig » Mon Jul 29, 2019 3:50 pm
Hi James,
Now that you are the proud owner, you can register it on 'MyAudi' and then when you have it fully activated by Audi (I had to take my V5 into an Audi dealer to prove ownership), you will then be able to see the full spec sheet \ options. From what you have said I think it is just the standard exhaust. I think both would have the valves and the difference will be to do with the mufflers but I could be wrong?! IF it was specced with the Sports Exhaust then I think it would have had black tail pipes.
Also just had a look at mine and my valves at both sides are open, I think this will be to do with what mode you are in when you switch off. So if in Dynamic then they will be open, if in Comfort then closed, but again I could be wrong...??!!
Cheers,
Lig.
jamesbilluk
Post by jamesbilluk » Mon Jul 29, 2019 4:04 pm
Hi Lig,
Thank you, ive downloaded the app, and set the car up, there's some of the spec there, I'll see if I can register it properly though.
Ah, that explains it then, I have my drive mode on individual, and the exhaust/engine sound set to dynamic all the time.
James
Lig
Post by Lig » Mon Jul 29, 2019 4:22 pm
Yeah, I could be wrong tho'. Try it next time in comfort and see if it changes? (I will try it too)!!
On the App, its 'Equipment Details' and 'Optional Equipment' that you need to see. I could only see this after full activation....
I don't suppose a squirt of WD will harm (as suggested by Uplandsway), although this might just burn off as I expect those parts will get quite warm!
Cheers,
Lig.
jamesbilluk
Post by jamesbilluk » Mon Jul 29, 2019 4:45 pm
I'll give that a go, strange that they were closed this morning, I had been on a drive in Dynamic mode on my favourite but or road so could have been from that too.
I must admit, when pushing on, it still does sound good, and certainly much louder than my last car, even with the standard system, this is with all the windows down though.
I've given both pipes a spray with WD40 too, just to make sure,
James
Tadass910
Post by Tadass910 » Tue Jul 30, 2019 10:18 am
jamesbilluk wrote:
Mon Jul 29, 2019 12:39 pm
Hi guys
James
Valves are always open when you shut off your car. Install Miltek none resonated exhaust with stock Downpipes and don’t look back, sound better than any amg or Bmw
jamesbilluk
Post by jamesbilluk » Tue Jul 30, 2019 1:58 pm
Hi guys
James
They do sound good! Would this set up drone on the motorway?
Tadass910
Post by Tadass910 » Tue Jul 30, 2019 3:26 pm
Hi guys
James
It depends what you call drone, for some people it’s okay for some not
uplandsway
Post by uplandsway » Tue Jul 30, 2019 3:40 pm
Like I said earlier the APR Cat Back is head and shoulders above the Milltek ( I had one on my RS6 previous) in both terms of quality, R&D and also sound.
https://www.awesomegti.com/shop-by-bran ... 7-4-0tfsi/
Cheers,
Stevie F
Tadass910
Post by Tadass910 » Tue Jul 30, 2019 4:15 pm
Maybe you had Miltek with cattles Downpipes, because if you put Miltek none resonated exhaust on stock Downpipes then it sound different instead of cattles Downpipes + Miltek none resonated
uplandsway
Post by uplandsway » Tue Jul 30, 2019 4:24 pm
Hi,
I ran Milltek Non Res with Stock Down Pipes before hand when i was stock then stage one APR :D
The APR Cat Back is on another level to the milltek, its like chalk and cheese... :jump_clap:
Cheers,
Stevie F
Lig
Post by Lig » Tue Jul 30, 2019 4:41 pm
Do you work for APR Stevie :lol: ?
Lig...
uplandsway
Post by uplandsway » Tue Jul 30, 2019 4:56 pm
Lig wrote:Do you work for APR Stevie :lol: ?
Lig...
HaHa, I wish Image.
But do think there products are at the top of the tree in terms of R&D, support, quality and price Image
Cheers,
Stevie F
Post by chunky79 » Tue Jul 30, 2019 7:22 pm
Hi,
You're wasting your time talking zorsts with MrMiltek, in fact, you're wasting your time replying to him full stop.
