Oil Consumption Concerns
Rich85
Post by Rich85 » Wed Oct 11, 2023 9:31 pm
Hi
Just wondering how people are doing for oil consumption, particularly on those that have had the oil separator done and more higher mileage examples.
Reason I ask is, in April @ 79,164 miles, I had Audi do a full oil change. I think the engine takes approx 8.5 to 9 litres of oil. I've just done a quick check in the MMI only to see it sat on the min mark and I'm now on 83,622 miles. So in just over 4k miles its managed to chomp away at all that oil which is very concerning.
The car seems to be running fine, doesn't appear to have any leaks but wondering if those who have had the oil separators done are experiencing higher oil consumption? Are there any other things I can check?
Rick
Veedub
Re: Oil Consumption Concerns
Post by Veedub » Wed Oct 11, 2023 10:56 pm
The difference between the min and max mark is 1L iirc.
Tadass910
Post by Tadass910 » Thu Oct 12, 2023 6:02 pm
These cars like oil) I am doing 15k km in a year and never get 1.5 liter to top up almost always go to change oil at my dealer
Rich85
Post by Rich85 » Wed Oct 25, 2023 10:01 am
Added a litre of oil which then showed 3/4 on the MMI. Then after one week it went up one notch and then down to 3/4 a few days later.
Car has now thrown me the check engine light, looking through an OBD scanner I’m getting two codes (P209600 and P12B700)
One relates to active post cat bank 1 running lean and the other is sporadic related to cylinder 8 cam adjuster.
Could these be early signs of the HPFP failing?
Tadass910
Post by Tadass910 » Fri Nov 03, 2023 10:38 pm
Try delete codes and see if they come back
Rich85
Post by Rich85 » Sat Nov 04, 2023 10:30 am
Light came back on after 160miles, turned out the sensor was just faulty, replaced under warranty but just monitoring the oil consumption for now.
Also do you know if the PCV is replaced when the strainer is done?
Tadass910
Post by Tadass910 » Sat Nov 04, 2023 8:34 pm
My PCV was replaced by Audi but I needed to pay, my car was whistling like hell
Users browsing this forum: No registered users and 152 guests
