4.0TFSI Turbo failure
Paulm
Re: 4.0TFSI Turbo failure
Post by Paulm » Mon Sep 23, 2019 11:55 am
Tadass910 wrote:
Mon Sep 23, 2019 11:42 am
Jaz9443 wrote:
Sun Sep 22, 2019 4:35 pm
Hi All,
I’ve recently experienced the same issue on my C7 RS6. Oil strainer blocked and considerable damage to the turbo housing. Currently being refurbished. Due to come back to my mechanic next week so hopefully will have her back on the road. Although I have high miles it’s still 2015 and disappointing such an issue could occur!
High mile means how much miles?
Paulm wrote:
Wed Sep 18, 2019 10:58 am
Sorry to hear. pretty poor design. Must be thousands of these engine just waiting to fail given they are used in various models all over the world. Not good.
I miss my V8TT but not the pain it was causing. Turobs, injectors, valve springs and sticking oil scraper ring all issues that seem to be getting more common. None of which are cheap to fix.
If anyone wants a link to very cheap turbos (and seemed very very good quality) give me a shout
Every tuner sais that this engine is a masterpiece that Audi done, and you say otherwise, maybe there are minor issues to some engines, but this 4.00 tfsi engine most reliable in Audi history. Of course you need to take care about your engine change oil every 15.000 km at least and do all services.
I was referring to the oil feed design. 10000% bad design, don't care who says anything different. You just need to look at all the failures popping up.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
Paulm
Post by Paulm » Mon Sep 23, 2019 12:05 pm
uplandsway wrote:
Mon Sep 23, 2019 11:47 am
I’d be interested to see the engine oil changes on these cars out of curiosity more than anything
Mine has been tuned since December of last year and have done engine oil service and spark plugs amongst other things every circa 5k miles..
Mine had full dealer history. Can't remember the mileage frequency as I sold it once fixed
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Golfather
Post by Golfather » Mon Sep 23, 2019 2:01 pm
Tadass910 wrote:
Mon Sep 23, 2019 11:52 am
For tuned car maybe every 5k miles is necessary to do oil change, but for stock car every 15.000km more than enough
Oil changes, tuning, service history, makes no difference at all!
Theres a reason why there is a revised oil screen design released by Audi. The previous design is prone to blocking and causing turbo failure
Just read up on all the reported failures!
Tadass910
Post by Tadass910 » Mon Sep 23, 2019 2:11 pm
So it should be changed under warranty?
uplandsway
Post by uplandsway » Mon Sep 23, 2019 2:25 pm
My car is a MY17, reg 31.12.2016 so should surely have the revised screen?? Image
Cheers,
Stevie F
2016 C7.5 RS6 Performance
dasquade
Post by dasquade » Mon Sep 23, 2019 5:20 pm
Lets not over dramatise it please :).
You make it sound the latest revision screen is the ONLY way to go, well guess what...without proper service even that one will clother up and make the turbo's fail.
It all depends how you drive the car, how you let it cool down, what oil you use, how frequently you replace oil and if you use oil cleaners imho.
Don't get me wrong, clearly there is an issue and it is especially sad the location of the screen is hard to get by (but what is on theseblocks!!)
Tadass910
Post by Tadass910 » Mon Sep 23, 2019 7:12 pm
So my question would be: shall I ask Audi dealer to change it just to be sure my turbos will last longer? My car is 2014 April and I have 111.000 km on
P.s is there any official bulletin by Audi that it’s shows that oil screen needs to be changed?
Golfather
Post by Golfather » Mon Sep 23, 2019 10:05 pm
reread first page of this thread:
viewtopic.php?f=76&t=132423&p=918598&hi ... en#p918598
TSB Details:
TSB (rev2) 2044640/2 November 21, 2017, listed these replacment parts:
079103175C Check valve
079115175G Oil strainer
These TSB revisions also listed the same screen (oil strainer) & check valve.
TSB (rev3) 2044640/3 May 14, 2018
TSB (rev4) 2044640/4 May 22, 2018.
TSB (rev5) 2044640/5 November 28, 2018
The version 1 of the Turbo TSB has the F revision turbo oil supply strainer (screen):
"21 Engine difficult to start, turbocharger damaged, V8 4.0TFSI
21 17 24 2044640/1 February 2, 2017"
"Production Solution
Not applicable."
"079103175C Check valve
079115175F Oil strainer"
Version 3 of the Turbo TSB:
"21 Engine difficult to start, turbocharger damaged, V8 4.0TFSI21 18 29 2044640/3 May 14, 2018"
Optimized oil strainer 079115175G for oil supply lines to turbochargers in the cover in the inner valley of engine. The oil strainer and check valve 079103175C must always be replaced to ensure proper oil flow to the turbochargers."
"079115175G Oil strainer"
BugsyM
Post by BugsyM » Tue May 11, 2021 10:34 pm
Golfather wrote:
Tue Jul 02, 2019 10:56 pm
Paulm wrote:
Tue Jul 02, 2019 9:15 pm
Sorry to hear. Pretty much guarantee it will be a blocked turbo supply oil screen. You must get it cleaned when you fit the turbos or they will just fail again.
The oil strainer must be replaced to a later superceded part, which does not get clogged as easily:
Original oil strainer:
079115175F
Revised superceded part, allowing much more flow:
079115175G
When was the later superceded oil strainer introduced in production?
shinefactorysf
Post by shinefactorysf » Wed Apr 20, 2022 12:29 am
Hello all,
A bit late in the game but some justice in the US for our predicament: the NHTSA have issued a recall for this issue just last month (2022 March) - at least some proactive recourse for others.
https://www.nhtsa.gov/vehicle/2013/AUDI ... WD#recalls
RCAK-22V178-9203.pdf
NHTSA Recall Document on Turbo Oil Screens
(629.88 KiB) Downloaded 121 times
adamza
Post by adamza » Wed Aug 10, 2022 9:03 pm
Came across this over Google and signed up to add that Audi UK has issued a recall to replace the oil strainers. 2016 FL. Work completed and just awaiting recalibration of cameras/parking sensors for the car to be returned. There is no warranty on the car due to age.
Tadass910
Post by Tadass910 » Fri Aug 26, 2022 9:34 pm
How long it took everything to do? Audi sais 3 working days.
Cathedrill
Post by Cathedrill » Mon Dec 05, 2022 4:00 pm
its late 2022 and this is still an issue. I had an S car that had this fault. Audi didnt even tell me, i found it myself by researching the car. i waited 7 months for audi to book me in. i also noticed a cylinder misfire but i didnt say anything, i wonder if they will notice anything. audi said it will take 3 full days to do this job, and their places get 1-2 cars a week....
Tadass910
Post by Tadass910 » Thu Dec 22, 2022 8:48 am
And? Did they changed it?
Users browsing this forum: Google Adsense [Bot] and 112 guests
