Cylinder Misfire Rs6 C7
Efterlyst
Post by Efterlyst » Wed Apr 20, 2022 10:25 pm
I have had misfire on cylinder 6 & 8 and now 8 is gone after replacing both turbos, both injection valves to the cylinders , all spark plugs. Also checking compression test on all cylinders and testing the coils with good results.
cylinder 6 misfire is still there and the engine runs very bad. I have changed oil, oil filter and air filter, also poured in 20l of good fuel.
What could I do more? :audibash:
morski
Re: Cylinder Misfire Rs6 C7
Post by morski » Thu Apr 21, 2022 12:20 pm
What does the diagnostic scan show? just the cylinder misfire? Swapped coilpacks from good one to no 6? Have you checked wiring with a load test?
Efterlyst
Post by Efterlyst » Thu Apr 21, 2022 1:12 pm
Yes only misfire on 6. What is a wiring with load test?
Audi checked all the coils with a “ociliscope” or something called like that and they were okay.
Tadass910
Post by Tadass910 » Thu Apr 21, 2022 9:31 pm
Interesting, if you were at Audi and they can’t solve a problem
Snowfree52
Post by Snowfree52 » Tue Dec 27, 2022 11:13 am
any update ?
Users browsing this forum: No registered users and 40 guests
