Car stalling on startup
Wattsm666
Post by Wattsm666 » Tue Oct 05, 2021 8:40 pm
I have a 2016 PE, which is occasionally stalling immediately after startup. It is due a plugs and filter change, waiting for the dealer to get them in.
I think this only happens when warm - any ideas?
HPsauce
Re: Car stalling on startup
Post by HPsauce » Tue Oct 05, 2021 10:29 pm
I don't know about the specifics of sensors on that car, but whenever I've seen similar problems (on my car or other peoples) it's been a faulty coolant temperature sensor.
It thinks the engine is colder than it is so over-fuels and "drowns" at idle. Cold starts are fine and so are warm starts if you apply enough throttle.
Might not be that of course...….
HDPete
Post by HDPete » Wed Oct 06, 2021 8:17 am
Mine did similar when the engine was warm. Never when cold. It turned out to be leaky fuel pumps - easily diagnosed by smelling your oil. If it smells like petrol, there’s an issue. If it’s due an oil change, it’ll be obvious when the oil is out whether this is the problem. If it is, it’s about £700 job to replace both pumps
Wattsm666
Post by Wattsm666 » Wed Oct 06, 2021 7:14 pm
Thank-you all, it will be going in soon to find out. Thankfully under warranty.
Markwes
Post by Markwes » Wed Oct 06, 2021 8:23 pm
Most likely to be the fuel pumps, I had the same issue, new fuel pumps cured the issue.
Audi RS6 c7 2014| Estoril Blue | Dynamic pack | Sports Exhaust.
Wattsm666
Post by Wattsm666 » Thu Nov 04, 2021 7:21 pm
Has now been fixed, was a problem with a vacuum hose on the turbo.
innercry666
Post by innercry666 » Fri Nov 05, 2021 5:54 pm
Glad to hear at has been fixed and what the issue was :-)
Have a good weekend!
RS6 PE - Current
RS4 (B8.5) 2015 - Sold
A4 3.0 TDI Quattro BE Avant - Gone
Focus ST170 - Garaged
