Milltek - Car sounds like a JOKE!
gary.gary.gary
Post by gary.gary.gary » Wed Oct 27, 2021 9:40 am
Guys, this is my RS6 with a Milltek non-res cat back systems installed, it sounds terrible, that high pitched chirping you can hear in the video is audible 80% of the time, and the overriding sound from the car in town and even on the motorway.
The fitting garage contacted Milltek with a video to have a listen and has sent me their email response - in which they say its normal on Audi S and RS cars - my advice - DONT BUY ONE.
https://youtu.be/rSK_NHgbtqw
MikeBirt
Re: Milltek - Car sounds like a JOKE!
Post by MikeBirt » Fri Oct 29, 2021 10:05 am
Still sounds lovely, aside the chirping.
Do you still have the valves in the exhaust or is it open 100% of the time?
If I did put another system on I;d want to keep the valves and have control over it for quiet cold starts.
Caino6
Post by Caino6 » Fri Oct 29, 2021 11:18 am
What an earth makes it chirp like that? Is it the Turbos you can hear spooling through the exhaust system now that there are less silencers? Would be interested to hear an explanation to the cause of the noise if anyone knows why it does that.
Daytona Grey Audi RS6 C6
732bhp 990nm
Nige_RS4
Post by Nige_RS4 » Fri Oct 29, 2021 11:47 am
Sounds like a tractor to me :) As above, did you buy the valved version? Maybe consider adding the resonated silencers to mute the chirping noise you don't like.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
bn8959
Post by bn8959 » Fri Oct 29, 2021 9:50 pm
I have the Road Plus version and is definitely doesn’t sound like that
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
MountainMutant
Post by MountainMutant » Sat Oct 30, 2021 9:51 am
I have the non res.
Mine has a rattle on coasting and gentle revs. Valves are set open all the time.
Miltek also told me this was normal.
They are pretty poor quality if you ask me and I’m looking to change mine
2017 RS6 PE Nogaro 💙
innercry666
Post by innercry666 » Sat Oct 30, 2021 11:34 am
Listening to the video, it is the engine that doesn't sound right. How does the car drive and how does it sound under load?
RS6 PE - Current
RS4 (B8.5) 2015 - Sold
A4 3.0 TDI Quattro BE Avant - Gone
Focus ST170 - Garaged
S4_V6T
Post by S4_V6T » Wed Nov 03, 2021 9:21 pm
I have the non res on my S8 and it sounds really good in my opinion. There is slight tractor sounds that gets emanated on idle and light acceleration but apart from that when in Comfort or Efficiency mode sounds slightly louder than stock whilst cruising and much better than stock on WOT. The valves do rattle sometimes but they are not too loud in my opinion. Try some WD-40 in the tail-pipes and leave overnight, see if it helps with the valves and if so buy a good supply of it!
When in Dynamic Sports mode, becomes wild and it may be a bit too much tbh to drive about in all the time unless you are really light footed. The valves are open in this mode, so they don't rattle.
https://www.youtube.com/watch?v=Ic9rqL7Bl38
https://www.youtube.com/watch?v=3ZdVhN2qb9Y
gary.gary.gary
Post by gary.gary.gary » Mon Nov 08, 2021 9:15 pm
It drives and sounds like it should in general, just have to ignore the stupid chirping.
This started when I had the centre section replaced under warranty (bracket sheared off the original section). I have now had the bracket welded back onto the original section and had it refitted. Hey presto .....the stupid noise is 90% gone. That's proof that the section was the issue....Yes I still get very mild chirping but its almost inaudible...and I've seen other RS6 owners complaining of the same.
Seems to me, it must be air flow issue in the exhaust, and worst still, there are differences from one system to another.....
I know I'll not buy another Milltek....its like rolling a dice.
wrekka
Post by wrekka » Sun Nov 21, 2021 11:21 pm
That deffo does not sound right. Has it been fitted correctly? I have had 2 x c7 rs6s with millteks in the past and neither sounded like that. Speak to an audi tuning specialist for further advise such as mrc etc. Send them your videos for their opinion
TTS RS4 -amazing machine,
Previous:
UrielsMachine
Post by UrielsMachine » Mon Nov 22, 2021 10:52 am
My non res Milltek ‘chirps’. WD40 sorts it for a while.
718 Cayman S - Manual box, PASM, Sport Chrono… it’s a joy.
RS6 c7 - a beast but now gone.
RS4 b5 - wish l’d kept it…
Tadass910
Post by Tadass910 » Sun Dec 05, 2021 2:30 pm
Is your car stock only Miltek non resonated exhaust installed? As I understand when you install exhaust everything was ok? And it started only when you changed center section
Users browsing this forum: RS6108 and 117 guests
