Intermittent Misfire
andywaddy
Re: Intermittent Misfire
Post by andywaddy » Wed Aug 03, 2016 7:11 am
MikeFish wrote:Looking back at yours, mine seems worse!
Cheers for that Mike.
Mine has just ticked over onto 7000 miles if that helps. I'm guessing you didn't have a P0305 code logged as well?
Changing my cyl 5 coil pack seemed to cure my P0305 misfires as none of those have been logged since I swapped it out for a new one but it's still logging misfire increments in that live data logger. The majority are happening when idle and if I hold the revs around 2.5k they'll happily count up 3 or 4 at a time.
I stopped in at Audi the other day to log it with them and as per usual, they had no idea about the bulletin...shock. I'll keep this post updated when the software fix gets released.
Magido
Post by Magido » Sun Oct 16, 2016 9:53 am
I had the exakt same problem.
I was driving in aprox 60mph and pressed a kickdown (Without any pre-throttle too show the car i was about to accelerate away)
the engine light (yellow) were beeping / flashing for around 5 seconds then its gone again.
So this is not anything to worry about?
Audi RS6 Misano build viewtopic.php?f=121&t=122026
Audi RS6 Misano & Audi R8 White Pictures https://postimg.org/gallery/19xrelsxq/
Leo-RS
Post by Leo-RS » Mon Oct 17, 2016 7:32 am
Magido wrote:I had the exakt same problem.
No, I suspect you've just caught the cylinder on demand out, the solenoid can be slow to respond with kick down from 4-8 cylinder switch.
You should perform a full 3rd/4th gear run in dynamic just to make sure that it pulls all the way through though (Away from 4cylinder mode) If you spot a flickering engine light, obviously come off the throttle.
MY16 Audi RS6
2013RS6
Post by 2013RS6 » Wed Jun 20, 2018 12:17 am
2013 RS6 43k miles
attached photo taken with my note 8 whilst using VCDS ... my counters are random ... cylinder 5 though not so much as cylinder 1 ... I have just purchased this Audi (parted my M5) and could feel the misfiring in the drivers seat ... just a tad now and then ...
I have also monitored the live data of misfires per 1000 rpm across the cylinders and the misfire is random on cyl 3 , 4 , 5 ,6 for the 10 minutes I was watching it ...
More concerning though is knock detection voltage on cyl 4 18.xx volts ... all the others are up to 3 volts ... is this correct? Is this reason for concern ?
attached pics .
I`m going to get the coils and plugs replaced as I can`t see any record of these being done and knock wood the misfires will go away ... I just finished a nightmare with my M5 and I just moved back to audi ... I hope this is better but as it turns out first day it misfires ... jeeez
2013RS6
Post by 2013RS6 » Wed Jun 20, 2018 12:18 am
other pic. for some reason won`t upload ... image invalid ... even made it smaller thinking that there is a size restriction ...
sefik
Post by sefik » Wed Sep 08, 2021 11:38 am
Hey! I have read that more people had the same problem with missfire cylinder 5 and engine light flashing. happens to me when it's colder outside. Has anyone solved it?
Audi rs6 c7.5 performance tuned
Users browsing this forum: Google [Bot] and 166 guests
