20 inch wheels
- Asian Panda
20 inch wheels
Hi all,
Can anyone confirm if the 2016 C7.5 with stock steel brakes can take 20" alloys?
Standard wheels were the 21s but would like to consider putting 20s on.
2016 RS6 C7.5 Sepang Blue
Re: 20 inch wheels
Hey dude,
Im running them with no problems. I am running spacers. But im pretty sure even without them they fit. As they were still a standard fit item on 7.5’s
Craig.
Craig.
- Asian Panda
Re: 20 inch wheels
Bud are you still using the standard steel RS brakes?
What size of 20" you using?
- Christiaan
- 1st Gear
Re: 20 inch wheels
The standard fit wheels for the C7 RS6 were 20” and the OEM 20’s fit over the steel or ceramic brakes.
- Asian Panda
Re: 20 inch wheels
Cheers mate. Sorry for sounding dumb. Most who I've asked had no clue and I wasn't sure as mine came with the OEM 21s.Christiaan wrote: ↑Wed Jun 23, 2021 10:22 pmThe standard fit wheels for the C7 RS6 were 20” and the OEM 20’s fit over the steel or ceramic brakes.
I assume there was no change in wheel size from C7 to C7.5?
Re: 20 inch wheels
Yeah I’m on std steels with oem 20’s
- Christiaan
- 1st Gear
Re: 20 inch wheels
No change in wheel size between C7 and C7.5.Asian Panda wrote: ↑Thu Jun 24, 2021 8:45 amCheers mate. Sorry for sounding dumb. Most who I've asked had no clue and I wasn't sure as mine came with the OEM 21s.Christiaan wrote: ↑Wed Jun 23, 2021 10:22 pmThe standard fit wheels for the C7 RS6 were 20” and the OEM 20’s fit over the steel or ceramic brakes.
My car is a 7.5 and came with 21’s but I also have a set of 20’s that I use for my winters and they were sourced from a C7.
Re: 20 inch wheels
They’ll definitely fit. In winter I use original skinny (245 wide) winter wheels and even they fit. C7.5
- Asian Panda
Re: 20 inch wheels
Don’t see why not. My winter set up is 245 40 20 8J ET 25.
Re: 20 inch wheels
It will all come down to barrel and spike design. So test fitting a non OE set of wheels would defo be recommended
Users browsing this forum: Google Adsense [Bot] and 131 guests
