What’s the right procedure for reading codes?
HDPete
Post by HDPete » Wed Jan 29, 2020 7:41 am
What’s the advice on reading fault codes with VCDS? Do I ignore anything that comes up first, then do a reset and read the codes again later, or are the initial codes valuable info?
HPsauce
Re: What’s the right procedure for reading codes?
Post by HPsauce » Wed Jan 29, 2020 10:04 am
Initial codes are always useful so record them before clearing.
Go through them and look for anything that correlates with known problems on the car or could be indicating a potential hidden issue.
That's assuming this is a car you own and have driven for a while...…
Basically use common sense. :wink:
Is the car new to you or VCDS?
HDPete
Post by HDPete » Wed Jan 29, 2020 2:55 pm
Hi
Many thanks. I’ve had the car for 3 years and I’ve used VCDS to do a few tweaks before. Thanks for the advice
