7.5 performance coolant level/use
Joe1199
Post by Joe1199 » Mon Jun 24, 2019 8:00 am
I have a 2018 PE, has now done nearly 8000 miles but I noticed yesterday that the coolant level is getting close to
The low level on the header tank.
Sometimes when i get out of the car and it is hot I can slightly smell coolant but I had an S3 and I seem to remember this being the same
I have no record of the level when I bought the car,
It was just lower than expected when I looked
Any possible reasons for this?
I have checked the common rupture point at the rear of the engine and it is well clear
ab54666
Re: 7.5 performance coolant level/use
Post by ab54666 » Mon Jun 24, 2019 8:53 am
viewtopic.php?f=76&t=118820&hilit=Coolant
Mine (pre FL) has always been nearer the minimum than maximum but has never moved.
Should coolant be changed at a regular interval?
dasquade
Post by dasquade » Mon Jun 24, 2019 2:21 pm
An other coolant leak source is often the in and outlet of the coolant pipes on both turbos. Easy to find out if you remove engine cover and have a look at the 3 pipes coming out the turbo's. The two outer ones are coolant, inner is oil (+ 1 oil line underneat but not visible). The pipes have a rubber o-ring witch then to wear out due to heat and start to leak. Visually very noticable if it has a wet spot around it or started building dark crusty carbon...
Joe1199
Post by Joe1199 » Mon Jun 24, 2019 4:45 pm
Thanks for the replies, would be a little disappointed if it was a leak from something other than hitting something on one of the rads etc as the car is barely a year old!
Another thought I had which could be similar to the issue above is that it has always been at that level and I didn’t notice, or perhaps there was an airlock which released over time?
I have topped it up and will keep an eye on it
Post by MikeFish » Mon Jun 24, 2019 4:47 pm
Pretty sure mine used to use a little coolant over time. Not a lot but maybe enough to give it a little top up once in three years.
ab54666
Post by ab54666 » Tue Jun 25, 2019 1:11 pm
If topping up make sure you get the right stuff, think it’s G13.
Users browsing this forum: Bing [Bot] and 63 guests
