The Mapping coin
uplandsway
Re: The Mapping coin
Post by uplandsway » Fri Apr 19, 2019 4:54 pm
Dyno Figures aren’t everything.
Cheers,
Stevie F
2016 C7.5 RS6 Performance
Steeleyp
Post by Steeleyp » Tue May 14, 2019 7:32 pm
DaveBee wrote:
Mon Jan 28, 2019 11:56 am
B-ill wrote:
Mon Jan 28, 2019 11:50 am
i'm curious to know how economy is affected under normal driving conditions with a map, do you still retain 4cyl mode?
Yes 4 cylinder mode is still available - I've seen it when slowing down :). I get 16 to 18 on a local shopping run and anywhere between 22 to 30 on a mw run depending on how I feel like driving. Thats with a remap that gave me 700HP, 1000NM torque and a remus exhaust that bumped both of those up a little. I don't regret it for one second.
Hi David,
I wondered if you were happy with the Remus. I’m keen on buying the cat back and think it’s sounds throaty.
Had an Akra on my B8 RS4 And was very happy with that.
Any feedback on Remus for the C7, hoping it’s not boomy/droney but videos never really tell ya. Appreciated
DaveBee
Post by DaveBee » Wed May 15, 2019 9:35 pm
Sorry, haven't checked in for while. Very happy with the Remus. It can be a little droney but only when in comfort mode, D8, under labour. Knock it down to 7 or Sport Mode and all droneyness goes away. I did eliminate the front silencers and so this probably accounts for that. The noise is just right for me, it screams business and power without being a yob with an asbo if that makes sense :)
David
Steeleyp
Post by Steeleyp » Thu May 16, 2019 8:37 pm
Thanks. You’ve helped steer me over the line. The Remus is the one. Many thanks
Steeleyp
Post by Steeleyp » Tue Jun 25, 2019 10:51 am
Got the Remus on. Full system from catback. Very happy, it’s definitely a deep note, not at all raspy. Very good quality and was a super easy fit.
The noise can keep you fairly low key at low slow revs but claps like thunder on high rev manual mode shifts.
ab54666
Post by ab54666 » Tue Jun 25, 2019 1:10 pm
My warranty will be up in October so considering mapping.
MRC clearly the place to go, probably goes against the grain but rather than push it to where problems can occur can you do a stage 0.5, ie low to mid 600’s rather than mid to high 600’s?
uplandsway
Post by uplandsway » Tue Jun 25, 2019 6:58 pm
ab54666 wrote:My warranty will be up in October so considering mapping.
Not sure of your RS6 flavour but check these out Image
http://www.goapr.co.uk/products/ecu_upg ... s6rs7.html
Cheers,
Stevie F
Users browsing this forum: rshales007 and 55 guests
