Rear brake pads
- Toffeebananas
- 1st Gear
- Toffeebananas
- 1st Gear
Re: Rear brake pads
Not one of these then!
Re: Rear brake pads
No, VCDS needs to be used due to the electronic hand brake, you can try it that way but you will end up wrecking the handbrake servo.
- Toffeebananas
- 1st Gear
Re: Rear brake pads
Thank you
Guesing the front callipers are ok to wind back the normal way?
Re: Rear brake pads
Correct.Toffeebananas wrote: ↑Tue Feb 05, 2019 9:04 pmThank youGuesing the front callipers are ok to wind back the normal way?
Some people have tried winding the rear ones like normal (on the A6 rather than RS6 but same thing) and reported no issues but not worth the risk if you ask me.
Re: Rear brake pads
you can disconnect the motor and wind them back in and then connect the motor back up its not a big job if you don't have access to VCDS
Re: Rear brake pads
Just done mine, used the OBEleven, all very simple, with the Brembo pads you get 2 wear sensors for some reason?
Users browsing this forum: No registered users and 60 guests
