Hi All,
thanks to a lovely pot hole (remind me again why we pay road tax) i've got a slash in the front left tyre wall. Both fronts are on 6.5mm so there question is, replace a single tyre or will it need both? Luckily, the alloy looks totally untouched, well visually anyways
cheers for any advice guys
Replacing tyres - In pairs or single tyre if other side is 6.5mm
chandler99
Re: Replacing tyres - In pairs or single tyre if other side is 6.5mm
Think you be ok
Could always go nearly new on eBay? Some good tyres with nothing wrong with them...all brands and depths?...one with similar tread wear?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
I'd replace both fronts, but keep the good one as a spare if you have another puncture.
As Chris said above, get a part worn tyre off eBay, 6-6.5mm, run it until both fronts are worn then replace with new.
I’ve had loads of part worn tyres off eBay before and never had a problem.
Audi RS6 c7 2014| Estoril Blue | Dynamic pack | Sports Exhaust.
Personally I don't trust second hand p/w tyres. You have no way of knowing their history and whether there is any hidden damage to the carcass. For the one component that sit's between me (+ passengers and car) and an accident I want to know it's in great shape!
If you do go down the part worn route, at least do yourself a favour and put it on the rear.
Same thing happened to me. Very annoying, trouble is you risk winding up the front diff I guess when I spoke to the Audi senior tech . But chances are low .
2017 C7 RS6 PE Nardo
2014 911 991 C4S PDK White
2013 M6 Cab Blk
2012 911 997 MK2 PDK Silver
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
I’ve read that the tolerances stated by Audi are 3/32” on the rolling radius of all 4 tyres. So basically as long as your tyres are with in roughly 2mm of each other it’s not an issue and as the OP states, his tyres are on 6.5mm. Putting one new tyre on which will have 8mm tread would be fine.Anth wrote:Same thing happened to me. Very annoying, trouble is you risk winding up the front diff I guess when I spoke to the Audi senior tech . But chances are low .
Audi says a maxium of 2mm difference on same axe to prevent problems . Side wall damage is a pain in the arse for sure .Markwes wrote: ↑Wed Nov 14, 2018 9:52 pmI’ve read that the tolerances stated by Audi are 3/32” on the rolling radius of all 4 tyres. So basically as long as your tyres are with in roughly 2mm of each other it’s not an issue and as the OP states, his tyres are on 6.5mm. Putting one new tyre on which will have 8mm tread would be fine.Anth wrote:Same thing happened to me. Very annoying, trouble is you risk winding up the front diff I guess when I spoke to the Audi senior tech . But chances are low .
2013 M6 Cab Blk
2007 RS4 Cab Grey
2013 M6 Cab Blk
2007 RS4 Cab Grey
Users browsing this forum: Google [Bot] and 63 guests
