Spacers... where to source? Fitting?
Surrey Sam
Re: Spacers... where to source? Fitting?
Post by Surrey Sam » Sun Apr 15, 2018 12:29 pm
Brooner wrote:
Sun Apr 15, 2018 12:14 pm
Surrey Sam wrote:
Sun Apr 15, 2018 12:13 pm
Remind me what you're running on your B8 again Brooner, 8mm or 10's?
10mm front and rear been on for couple of years now with no issues
Cheers, must get some sorted :thumbs:
Post by MikeFish » Sun Apr 15, 2018 12:30 pm
Singhaa88 wrote:
Sun Apr 15, 2018 12:26 pm
Yeah I’ve just looked at them now...
Stone chips? Huh?
I just want the wheels to sit a bit more flush, giving it a slightly wider stance...
Are you saying I’ll have to lower it as well as space it?
No I wasn't saying that; lowering is a personal preference, I think it looks much better but others think it looks fine without lowering.
But if you move the wheels further out you will be more prone to stone chips.
Singhaa88
Post by Singhaa88 » Sun Apr 15, 2018 12:39 pm
Ah ok with you... doesn’t the standard suspension drop a little when you put it in Dynamic mode? ...
I’m not against lowering it to be fair... but was just wanting to widen the stance before I have an alignemrnt done, that’s all
Audi RS6 C7 2015 - Sepang Blue
Previous; 997.2 GTS, 997.2 C2s, 997.1 C2s, Jag XFR-S
Brooner
Post by Brooner » Sun Apr 15, 2018 1:46 pm
Glenn will sort you out
got the bolts and locking nut from him too you just need to pack out the locking bolt cover as the standard one is a little to big and will fall off otherwise
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Post by MikeFish » Sun Apr 15, 2018 5:02 pm
Only if you have the air suspension.
Singhaa88
Post by Singhaa88 » Sun Apr 15, 2018 5:37 pm
Hi mike I presume I do as it mentions air suspension in the MMI and I can raise the car if needed in the MMI etc?
Post by MikeFish » Sun Apr 15, 2018 6:16 pm
Yes, sounds like you have air suspension.
Singhaa88
Post by Singhaa88 » Sun Apr 15, 2018 8:36 pm
Yeah ok so basically I space the wheels then and always ride in dynamic mode lol...
NME
Post by NME » Sun Apr 15, 2018 8:50 pm
You can also lower it further in the settings of the car with VCDS if you want, or buy a set of lowering links which also lower it.
You can also buy a module which lets you adjust the height on the fly from the MMI via an app in your phone.
HDPete
Post by HDPete » Sun Apr 15, 2018 9:08 pm
Is there a handy guide for lowering in VCDS that’s been tried and tested? (C7.5 PE)
Post by MikeFish » Sun Apr 15, 2018 10:42 pm
Don't think anyone knows the security code for facelift cars to do it with VCDS yet.
NME
Post by NME » Mon Apr 16, 2018 5:14 pm
I’ve got a FL and the security code for the suspension is the same as non - FL.
The only code that isn’t able to be cracked is the ability to change the speed that the VIM kicks in, which is different.
Well, it was for mine anyway. I’ll have a look for the code.
NME
Post by NME » Mon Apr 16, 2018 7:45 pm
https://www.audizine.com/forum/showthre ... -with-VCDS
Users browsing this forum: Quinten and 111 guests
