Shift lights
Northerner
Shift lights
Post by Northerner » Tue Sep 19, 2017 10:03 am
Still trying to work out stuff on the car and dont appear to have the shift lights when in the lap timer screen:
Is there an option to enable?
zzz
Re: Shift lights
Post by zzz » Tue Sep 19, 2017 10:26 am
iirc they only activate when you're actually accelerating the car.
Northerner
Re: Shift lights
Post by Northerner » Tue Sep 19, 2017 11:20 am
Tried that, going right upto the red line when driving in manual and using all the different car modes.
gsc
Re: Shift lights
Post by gsc » Tue Sep 19, 2017 12:01 pm
I'll check later but I seem to recall mine show in the HUD rather than on the DIS
zzz
Re: Shift lights
Post by zzz » Tue Sep 19, 2017 12:47 pm
That is the correct screen. Just tested it, the green bars go up very quickly on full boot & clearly turn to red once you're in the red line:
The display box is not there when idling, it appears once you're on the move.
Northerner
Re: Shift lights
Post by Northerner » Tue Sep 19, 2017 12:53 pm
The only difference i can see between the photos is that yours has a flag symbol next to the time. Is yours in sport mode?
zzz
Re: Shift lights
Post by zzz » Tue Sep 19, 2017 1:11 pm
It was in individual. Everything on dynamic apart from steering (comfort) and air suspension (auto)
Edit: Not 100% sure but I think the flag by the clock (top right) was telling me when I was going to reach the destination. Bottom left is the icon to tell I've caught a satellite
Zeebuilder
Re: Shift lights
Post by Zeebuilder » Tue Sep 19, 2017 6:16 pm
The only way it works is when you move the gear knob over to manual and not just by using the paddle shift to select manual. Hope that makes sense
Northerner
Re: Shift lights
Post by Northerner » Tue Sep 19, 2017 6:40 pm
Worked it out on the way home. The shift lights only show up on the heads up display and not the dash.
skirs6
Re: Shift lights
Post by skirs6 » Tue Sep 19, 2017 9:04 pm
Do all C7 have this lap timer option ?? Looks quite cool. Won't test it just yet as still running in the new engine😩😩
Re: Shift lights
Post by MikeFish » Wed Sep 20, 2017 8:04 am
skirs6 wrote: ↑
Yes, it's the same screen that tells you the oil temperature and has the boost gauge ie the most useful screen. What do you normally have it on?
skirs6
Re: Shift lights
Post by skirs6 » Fri Sep 22, 2017 7:45 pm
MikeFish wrote: ↑
skirs6 wrote: ↑
Yup found itπŸ‘ I normally have it on the efficiency. Turn the aircon and heated mirrors off and it goes blackπŸ‘ I’ve done 300miles since the new engine so nearly time to open it upπŸ‘πŸ‘
whiteq
Re: Shift lights
Post by whiteq » Mon Sep 25, 2017 6:35 am
I'm also unable to see the shift light, I had it enabled in my C7 S6 on the DIS, however in the C7.5 RS6 I am unable to get the shift lights on the DIS or the Heads up.
Any tips?
Tadass910
Re: Shift lights
Post by Tadass910 » Mon Sep 25, 2017 12:56 pm
Northerner wrote: ↑
You are wrong, they showed in both in hud as well in dash, you need to be in manual mode and use shift paddles
whiteq
Re: Shift lights
Post by whiteq » Mon Sep 25, 2017 10:44 pm
I did that and still nothing...
Return to β€œRS6 (C7 Typ 4G) 2013-2018”
Users browsing this forum: No registered users and 142 guests
