Interesting. Might have a look at that, but now I have the delete units there is no need I guess; one less thing to worry about recoding if Audi ever update my software. Also, the delete units stop any dirt getting into the sockets.Magido wrote:1). Engine module
Byte 9
Bit 2 - exhaust flaps installed (uncheck that)
Should be able to keep the flaps open permanently thrue VCDS.
Miltek straight pipes
Re: Miltek straight pipes
Yes, they plug into the plugs you pull off of the exhaust valves.RS6chris! wrote:Do these plug into wires From car to valves?
Can buy from UK supplier here:scurryz wrote:MAgido here is a link to buy the miltek delete units. http://www.g-werke.com/exhaust-accessor ... dule-pair/
http://www.venommotorsport.com/product/exhausts/EX1504/
I know it says Audi A3 but they have the same part number and I bought mine from here and can confirm they work.
Ah cool thanks mike. btw does this mean that you need to buy two since i believe the a3 only have one exhaust pipe
Current 2007 Black Rs4 B7,
Gone Bmw 118d, S4 b5, RS4 b5, A6 2.7t, passat cc, A4 1.8t, RS5 b5, 2012 A7, 2013 Phatom black RS6
No they came as a pair.scurryz wrote:Ah cool thanks mike. btw does this mean that you need to buy two since i believe the a3 only have one exhaust pipe
Ordered the downpipes and catless midpipe now
So i will soon have the full turbo-back catless none resonated system..
A friend of a friend is working on a Bluetooth unit that you plug in to OBD-port on VAG-cars so that you can open and close the valves with your smartphone (Or a switch in the car if you prefeer)
I really hope he suceed. Would be aweeesome
Preliminary install-date next Saturday! (in 9 days)
Audi RS6 Misano build viewtopic.php?f=121&t=122026
Audi RS6 Misano & Audi R8 White Pictures https://postimg.org/gallery/19xrelsxq/
Afaik Milltek itself was/is working on their own can-bus module that allows you to custom 'remap' the ECU valve system.
Last time i checked with them they were testing it out on the BMW platform but were working on it for Audi.
At least for the BMW customer was able to manually program 'any key' in the car (steeringwheel for example) to manually bypass the vavle open/close.
Apperently it is out already, haven't checked with them if this is correct and at what price...
http://www.valvesonic.com/
Hmmm, i think i confuse it with the vavlesonic 'plus' module. That is out already for the BMW platform. Not sure how it is different then the audi 'module' shown on their images on their site. Maybe this features the 'custom button mapping' where the first module is without the button mapping.
http://www.millteksport.com/product.new ... icleid=178
I had a quick check today...Magido wrote:1). Engine module
Byte 9
Hmm, looks somebody had already unchecked my flaps! Still doesn't answers why the left valves was stuck in the close position :s.
Guess i'll have to check it back on, cross finguers the module reopens it in good position and then uncheck it back.
Regarding my earlier milltek module, they are still working on it. ETA unknown...
Can anyone confirm 100% this works?dasquade wrote:I had a quick check today...Magido wrote:1). Engine module
Byte 9
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Apperently it doesn't :s as somebody else checked it too and it was already unticked aswell (but also didn't had labels on the box so we don't know if the above is correct).
Personally also still looking for conformation or a decent 'oem' fix (manual controle over the flaps....in any mode).
It does not work. My was already unchecked and the valves were still closed.
Right now i want the valves too be closed tho
