Guys
Can't find anywhere even in manual?
How many litres of oil for a standard oil change?
Chris
Oil change? How much oil?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Re: Oil change? How much oil?
BLAU® oil change kit features:
9 Liters Of German Ravenol VPD 5w40 Motor Oil - Approved Audi motor oil quality standard 502 00 and 505 01 required for 4.2L RS6 gasoline engines. It is recommended to use a 505 01 diesel spec oil to offer RS6 engines better high heat stability and protection.
1 Oil Filter (German Mfd.)
1 OEM Oil Pan Drain Plug Washer
Zero Drama
Thank you...
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
boff wrote:No problems. Hope the spacers are going well!!!
Fantastic!! Even better once I've lowered it next month...
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Boff is quoting the 4.2l engine above used in the C5 RS6's
Although you will still need 9litres, you'll specifically be wanting VW502.0 spec oil.
Correct info below...
http://www.blauparts.com/proddetail.asp ... 1A5131%2DE
MY16 Audi RS6
- feeltheburn
Firm Believer in RTFM but just can't seem to make sense of it at the moment.
I am on long life servicing and the RS is approaching 24months old. I chose to have an oil change done at 10,000miles- Shell Helix was what Audi supplied. I get from the manual that the oil needs to meet VW 504 00 spec for Flexible servicing and for Fixed Serving should be VW502 00 spec and that VW504 00 can be used on fixed servicing when using good quality fuel. Is there a reason why I would want to use VW502 00 spec oil instead of the VW504 00?
I am considering going to a fixed service interval, and want to supply the oil myself to shave a little off the bill(given I am having it done more frequently than I could). Should I be buying the VW502 00 spec or is it ok to use the VW504 00 spec; are Audi likely to insist on VW502 00?
Also what viscosity of oil is recommended 5W-30, 0W-30 or 5W-40? The can that came with the car is Shell 0W-30 [504 00 spec] so presumably that is what it should be . It seems Audi are now supplying Castrol rather than Shell oils, I guess it doesn't really matter if I now change to Castrol?
Any help appreciated
RS6 C7 (2014), Daytona Pearl, 21" Titanium, On Air, LEDs, Sports Exhaust, Dynamic Steering, Red Calipers, ACC, Top View, Connect, Tints, Rear Side Airbags, Rear heated seats; MP4S
Users browsing this forum: No registered users and 189 guests
