Pic of R8 steering wheel:
R8 system is very different to the C7 system, so can't see many of the buttons being able to be made to workdasquade wrote:Any update on this?
Scored this type of steeringwheel on ebay and should be getting an S6 C7 avant (11/2013).
Guess time will tell...
*i'm sure the start/stop button won't work, but at least hope the drive select works. At least the drive select works on the new rs6 performance steeringwheels fitted in the S6 C7 from what i read.
The RS6 PE Driver Select button is a reconfiguration of the customiser button (*), which is also present on this R8 wheel. If anything works at all , then your Driver Select is more likely to work via the * button than the dedicated "Driver Select" button, which is likely to send an unrecognised signal to the MMI.dasquade wrote:Any update on this?
Users browsing this forum: No registered users and 92 guests
