Cooling fan
fabrs4
Cooling fan
Post by fabrs4 » Fri Jan 02, 2015 7:40 pm
Hi gents, would like to ask your advice/thoughts on this one, after a short journey 4-5 miles and then turned off the cooling fan then starts and continues to run for about 4 minutes, the temperature gauge shows that it's not yet reached its operating temperature. The result of this is the battery is been discharged and as a rule the stop/start fails to operate as it should. Spoke to Stoke Audi and to honest tried to fob me off saying it was normal . Would appreciate any thoughts thanks
RSphantom
Re: Cooling fan
Post by RSphantom » Fri Jan 02, 2015 9:49 pm
Yep, mine does that as well, longer journey result in the fan staying on for more than that. My stop/start does not work when the engines is cold anyway. Usually a good 10 miles/15 mins or so before its starts working. It's will start working straight away if the engine is still warm on restart.
Nothing to worry about :beerchug:
2019 RS3 4 door - Gone
DragonRR
Re: Cooling fan
Post by DragonRR » Sat Jan 03, 2015 1:31 am
My fans ran on after turning the car off for quite some time. I've noticed this in all the cars I've had or used with turbos and have assumed it was to cool the turbos down rather than anything else. My current 911 TTS does the same. However I didn't notice this "feature" having any impact on Auto Stop/Start or excessively draining the battery.
Polo 895cc 81|Datsun thing 83|Astra Van 1.3 85|Escort 1.6 87|XR2 88|Renault 5 Trbo 90|Renault 21 Trbo 93|XR2i 16v 94|Jag XJ6 99|BMW M3 E36 01
BMW 328i E46 04 & Honda VFR750|BMW M3 E46 06|Jag XK8 07 & Honda CBR600RR|BMW 645CSI E63 08|BMW M6 E63 09|Audi S5 10|BMW M5 F10 12 blk
Audi RS6 C7 14 Dayt Grey|Vxhall Corsa 1.2LE Yell|Golf R 15|C63s Ed 1 Coupe|Porsche 911 991 Turbo S 14 Saph Blue|RS6 PE 16 Nogaro Blue|AMG GTS 16 Blue|M5 Comp White 18|Current: M5 Comp Snap Blue 19|Audi R8 V10+ Blk 18
Mcma1
Re: Cooling fan
Post by Mcma1 » Sun Jan 04, 2015 12:53 am
Same happens on my caddy van so must be the norm now. :) draws a fair bit off attention though as I lock and walk off from the rs6. My dad thought it was still running!
fabrs4
Re: Cooling fan
Post by fabrs4 » Sun Jan 04, 2015 10:03 pm
Thanks for the replies much appreciated
nuwanda
Re: Cooling fan
Post by nuwanda » Mon Jan 05, 2015 3:11 am
During summer here, my fan was on as long as 11 min after engine off even after non spirited driving.
Mazda Eunos 800M, Mazda Tribute 3.0, Toyota Harrier 2.4, Lexus IS250 Deluxe, Audi Q7 3.6, Golf MKV R32, Audi MK2 TT 3.2, BMW X1 xDrive25i, Audi S5 Sportback, MB C63 Estate, Audi RS6
Shinobi675
Cooling fan
Post by Shinobi675 » Mon Jan 05, 2015 10:26 am
nuwanda wrote:During summer here, my fan was on as long as 11 min after engine off even after non spirited driving.
Were you timing it! ;)
rabies
Re: Cooling fan
Post by rabies » Mon Jan 05, 2015 11:53 am
My C6 did this and my C7 does this too. Don't forget you have one hell of a lump of engine in a very small area. Plus both engines have a dry sump and so you have another radiator/cooler for the oil. Add to that a couple of large turbos and that's why they run cooling fans - the residual heat (even after a short run) is very high indeed and requires cooling to prevent damage
nuwanda
Re: Cooling fan
Post by nuwanda » Tue Jan 06, 2015 2:30 am
I did my friend....I did. :jump:
