IT Support Joke....
Posted: Wed Oct 06, 2004 9:16 am
For those of us that have/are suffering as IT support people
A plain computer illiterate guy rings tech support to report that his
computer is faulty.
Tech: What's the problem?
User: There is smoke coming out of the power supply.
Tech: You'll need a new power supply.
User: No, I don't! I just need to change the start-up files.
Tech: Sir, the power supply is faulty. You'll need to replace it.
User: No way! Someone told me that I just needed to change the start-up
and
it will fix the problem! All I need is for you to tell me the command.
10 minutes later, the User is still adamant that he is right. The tech is
frustrated and fed up.
Tech: Sorry, Sir. We don't normally tell our customers this, but there is
an undocumented DOS command that will fix the problem.
User: I knew it!
Tech: Just add the line LOAD NOSMOKE.COM at the end of the CONFIG.SYS. Let
me know how it goes.
10 minutes later.
User: It didn't work. The power supply is still smoking.
Tech: Well, what version of DOS are you using?
User: MS-DOS 6.22.
Tech: That's your problem there. That version of DOS didn't come with
NOSMOKE. Contact Microsoft and ask them for a patch that will give you the
file. Let me know how it goes.
1 hour later.
User: I need a new power supply.
Tech: How did you come to that conclusion?
User: Well, I rang Microsoft and told him about what you said, and he
started asking questions about the make of power supply.
Tech: Then what did he say?
User: He told me that my power supply isn't compatible with NOSMOKE.
computer is faulty.
and
User: I knew it!
10 minutes later.
User: MS-DOS 6.22.
1 hour later.
