Any Electricians on here
Posted: Fri Feb 26, 2016 7:17 pm
by Paulm
Got my new 2 post ramp to wire up but have no diagram and cant fine one on line.
pic of control box and diagram I got with the ramp.
Re: Any Electricians on here
Posted: Fri Feb 26, 2016 7:45 pm
by Surrey Sam
You'll probably need to get a Part P registered electrician to do the install; that way you'll comply with Part P of building regs and get certification for that. Actually...in Scotland it may be different - think its Building Standards or something to that affect?
Shouldn't cost too much. I had a generator wired up to the main house board with a switch over in case of a power cut and the job was done in less than an hour.
Posted: Tue Mar 01, 2016 7:55 pm
by Paulm
So turns out I was stitched up. guy said it was single phase ramp (only reason I bought it), but on investigation its 3 phase :knob:
Anyone use or know of a good VFD or single phase to 3 phase convertor?
its a dual power motor so I can wire it up DELTA configuration and still use 240volts no need to move to 380volts.
Posted: Wed Mar 02, 2016 1:04 pm
by daytonamart
Paul, I might be able to help, how many kW is the motor.
We sell variable speed drives that can work off a single phase input.
Mart.
Posted: Wed Mar 02, 2016 1:21 pm
by Paulm
3kw motor 230 /400v 16.5 / 9.5 amps
I see I can get them off ebay for around £120 - £170 (34amps 7kw) but reading other sites it seems to say you need huge power to start the motor e.g the ramp is 1/2 up and stopped I then want to raise it all the way.
think I might flog it and buy a new one. never thought I would miss my old 4 poster. must be over 25 years old and still going strong.
Posted: Wed Mar 02, 2016 1:28 pm
by daytonamart
Fair play Paul,
This might be your best option, the ebay ones are vastly cheaper than we could do one for.
