Focal 27K Bass Speaker and mounting Plate
Posted: Sun Oct 03, 2010 3:36 pm
by steverrquattro
The following item was taken out of an RS2 and is no longer needed :
11 inch Subwoofer: Polyglass 27 K Subwoofer for bass-reflex enclosure Woofer 27 K 270mm (11) subwoofer, 65mm (2-1/2) v.coil,156mm (6) magnet Midrange - Tweeter - Crossover - Max. power handling 600 W Nom. power handling 300 W Sensitivity (2.8 V / 1m) 90,5 dB Frequency response 30 Hz * - 1,5 kHz *Depend on load Fs 50,1 Hz Re 4,5 ohms Qes 0,67 Qms 5,61 Qts 0,60 Dia 21 cm Mms 76,0 g Lvc 1,79 mH Hbob 26 mm Hgap 8 mm Xmax 9 mm Sd 346,4 cm2 Vas 22,3 l BL 12,7 N/A Folding diameter 233 mm Mounting depth 117,5 mm Sealed enclosure (l.) - Bass-reflex enclosure (l.) 25 - 40 litres
£100 - bargain!
Image,Image
Cheers,
