Wanted: Secondary Air Pump for B5 RS4
Posted: Thu Sep 16, 2010 4:04 pm
by Contigo
Anyone got one of these going? Mine has started whining on cold start and I need it fixing before it goes.
I was tempted to remove it from the car altogether BUT I believe it can throw a CEL. Anyone know for sure if it does or not?
RE: Wanted: Secondary Air Pump for B5 RS4
Posted: Thu Sep 16, 2010 4:35 pm
by dace
Just had mine removed and re-coded. I would do the same If I were you.
Re: Wanted: Secondary Air Pump for B5 RS4
Posted: Thu Sep 16, 2010 4:40 pm
by dace
Contigo wrote:I was tempted to remove it from the car altogether BUT I believe it can throw a CEL. Anyone know for sure if it does or not?
Forgot to mention the ecu will need re-coding if removed.
RE: Re: Wanted: Secondary Air Pump for B5 RS4
Posted: Thu Sep 16, 2010 5:15 pm
by Contigo
Honestly mate not got time to go up to MRC or suchlike. I might just do this
http://uk-mkivs.net/forums/t/141240.aspx
Posted: Thu Sep 16, 2010 5:31 pm
by dace
I thyink you will find it is in a different position on the B5.
Posted: Thu Sep 16, 2010 5:39 pm
by Contigo
yes but the bodge should work right?
Posted: Thu Sep 16, 2010 10:57 pm
by stunew
i did this repair to the wifes MK4 GTI turbo, removed the pump, drilled out the rivets, split the casings, cleaned, lubricated the o ring with grease and reassembled with new bolts and nuts. been good for over 2 years now!
