Page 1 of 2
Wanted Rs4 B5 2.7 Engine
Posted: Fri Jun 25, 2010 4:42 pm
by Lozz
Planning to fit the engine into a kitcar so looking for
Engine, Turbo's, Ecu, MAF and Short Loom
Based in the midlands with cash waiting.
Regards,
Laurence
RE: Wanted Rs4 B5 2.7 Engine
Posted: Sat Jun 26, 2010 12:58 pm
by Blue_Thunder
Depending on the power you are looking to get out of it, you would be as well getting hold of a more readily available (and cheaper) S4 engine and just fitting K04 (RS4) turbos.
The S4 engine is good for 500ft-lb of torque before you need to think about upgrading internals.
Posted: Sat Jun 26, 2010 7:30 pm
by stumpyrs4
A tuned 1.8T would be better surely?
Posted: Sun Jun 27, 2010 9:28 am
by Lozz
Not sure how the 1.8 would surely be better.
Just taken out a z22se lump with a bespoke turbo, and getting up to the 300bhp was alot of work.
I understand that buying a S4 engine and just fitting K04 turbos is cheaper and you might be nearly up to the same power but cosworth did alot more than just changing the turbo's.
Posted: Mon Jun 28, 2010 9:00 am
by Blue_Thunder
Indeed Cosworth did do a lot of work (K04 turbos, intercoolers, Y-pipe, inlet manifold, block, heads, rods, cams, downpipes, pipework, etc). RS4 engines give better top end power, S4 engines have greater low down torque.
Fact is, you can pick up an S4 engine for a grand, and there's no shortage of them. Whack on some bigger turbos, intercoolers and injectors (i'm assuming on a kit car you will already have a suitable fuel pump and exhaust setup)and you've got an engine that will match a remapped RS4 engine.
RS4 engine's don't come up very often, and when they do they tend to cost upwards of £3k. Choice is yours, but I think you should do a little more research before discounting the S4 engine for your requirements.
Posted: Mon Jun 28, 2010 9:36 am
by Lozz
Ideally I was looking to pay around £2500 for an rs4 engine.
Never going to be a cheap project. As the engine will be mid-mounted I'll also need a a6 2.5 tdi gearbox, Bespoke loom, gear linkages, Exhaust.
Thats before we start looking at Air-to-liquid intercoolers.
I Looked at the s4 engine but it didn't have many advantages over the cheaper m3 e46 engine. If I'm going to spend every evening for the next six months under a car i'd rather spend the extra money and buy the best.
Just need to give up drinking beer and eating..............
Posted: Mon Jun 28, 2010 1:06 pm
by Blue_Thunder
Depends on what you class as advantages (clearly not torque or tuneability for you ;) ). I don't think the advantages of an RS4 engine over an S4 one outweigh the extra cost if you are starting from scratch (you would probably want to replace/refurb the turbos on an RS4 engine anyway).
Take a look over on AudiSRS and do a search for Author 'KHM'. He's already built a mid-engined kit car (Pulse GT1) using an RS4 engine. You may be able to pick up some ideas.
Good luck! :thumbs:
Posted: Mon Jun 28, 2010 1:15 pm
by Silversea
I think you'd really struggle to buy a complete RS4 B5 engine for £2.5K, even with lunar mileage.
As above, an S4 would be a cheap starting point IMHO.
Posted: Mon Jun 28, 2010 1:36 pm
by Lozz
I'm in no rush....See what comes along.
Posted: Mon Jun 28, 2010 5:23 pm
by Pau1
Lozz wrote: I Looked at the s4 engine but it didn't have many advantages over the cheaper m3 e46 engine. If I'm going to spend every evening for the next six months under a car i'd rather spend the extra money and buy the best.
Are you taking about the V8 S4 engine? Cause we're not. The 2.7 TT engine out of a B5 S4 is all your going to need.
Posted: Thu Jul 01, 2010 9:00 am
by Lozz
I was, Didn't realise there was two. I checked the s4 v8 2.7 bi turbo for size and it was a tight fit. How does the size comapare? Is the TT 2.7 engine very different?
Posted: Thu Jul 01, 2010 12:12 pm
by Lozz
Can't see how buying a S4 2.7 engine adds up.
Engine £1500, K04 turbos £900, Remap £500
Total £2900 - 350bhp?
Rs4 Engine 2.7
Engine £2750, Remap £500,
Total £3250 - 460bhp
£350 for an extra 110bhp seems like good value.
Either way i'm going to need a bespoke racing exhaust and 100 cell cat.
Posted: Thu Jul 01, 2010 1:29 pm
by stumpyrs4
Lozz wrote:I was, Didn't realise there was two. I checked the s4 v8 2.7 bi turbo for size and it was a tight fit. How does the size comapare? Is the TT 2.7 engine very different?
The S4 engine which is 2.7 litres is a V6 = 265bhp - with twin turbos - excellent for tuning, and is also the base engine for the B5 RS4 (2000/2001) = 380bhp.
The S4 engine in the B6 model car is the 4.2 litre N/A V8 = 344bhp - very limited tuning ability due to the fact it's N/A.
Posted: Thu Jul 22, 2010 3:21 pm
by Lozz
Still looking if anyone has one...
Posted: Thu Jul 22, 2010 4:36 pm
by telrs4
have you checked on ebay there is ars4 breaking?
