Wanted - Fuel Pressure Regulator
Posted: Sat Sep 26, 2009 9:09 pm
by ogg14
Hi there.
I was wondering if someone might have a Fuel Pressure Regulator for my S4 1999... Its coming up in Vag Com that this might be at fault (running lean on both banks) I have ran a pressure test through and didnt find any air leaks so this is my next option.. Does anyone have one for sale or knows what to replace it with...
I have checked on fleabay and they have adjustable ones... Does anyone know what these are like... any suggestions at all would be great thanks... I remember the stealers wanting around the £70 mark for them... if anyone can steer me in the right direction... any advice would be much appreciated...
Andy
RE: Wanted - Fuel Pressure Regulator
Posted: Sun Sep 27, 2009 8:07 am
by boxerdogted
How old is your MAF ? and when was your fuel filter changed.
Posted: Sun Sep 27, 2009 7:36 pm
by ogg14
Both of these were replaced just a few months ago... The maf was changed out when i got the car remapped and the fuel filter was changed out on the last service...
Andy
Posted: Sun Sep 27, 2009 7:46 pm
by boxerdogted
Take FPR off and check for dirt etc there is a filter in there.
Gareth
Posted: Sun Sep 27, 2009 8:42 pm
by ogg14
I didnt know that Boxerdogted... I will try taking it off and cleaning it. What do i use to clean/rinse it with?
Andy
Posted: Sun Sep 27, 2009 8:53 pm
by boxerdogted
Blow out any crap with an airline and check that it is not stuck open causing low pressure.
Remove the horseshoe clip and pull out, they are very tight to get out as they are sealed with two o rings.
Gareth
Posted: Sun Sep 27, 2009 8:57 pm
by ogg14
Cheers Gareth... Will try this and let you know how it goes... Cheers for the advice... much appreciated...
Andy
Posted: Sat Oct 03, 2009 10:36 am
by ogg14
Well i have just removed the FPR for cleaning the filter and there was nothing there. It was totally clean. It was a bit of a bugger to get back on but at least it was clean. I was hoping it was blocked but no, so what else can i try.
Would a upgraded FPR say from a rs4 be better or are these the same. On the FPR it says 4 bar... P/N - 078133534C
Any suggestions would be appreciative...
Andy
