Alpine MRP-T406 amp
Posted: Mon Mar 24, 2003 2:39 pm
I have one of the above for sale.
In mint condition, I used to have in powering the fronts in my A4, but would be ideal for use with a small sub also.
AS with all things Alpine it sounds great and is very well made.
PM me if interested.
Below are the specs:
Technical Details : MRP-T406
MAX POWER (EIAJ)
90W x 2 (4Ohm Stereo)
240W x 1 (Bridged 4Ohm)
RMS AT 14.4V, 20Hz-20kHz
40W x 2 (into 4Ohm, 0.08% THD)
60W x 2 (into 2Ohm, 0.3% THD)
120W Bridged (into 4Ohm, 0.3% THD)
GENERAL
Frequency Response: 10Hz-50kHz (+0,-1dB)
S/N Ratio: 100dBA
FET DC-DC Power Supply
Built In Divider (HP/LP, 80Hz, 12 dB/oct.)
Crossover Frequency (12dB/Oct.): 80Hz
Input Sensitivity (V/at 10Kohm): 0.2-4.0V
Dimensions (mm) W x H x D: 226 x 36 x 140
Fully Discrete Preamp Stage
Duo-ß Circuit
Speaker-Level Input
Top Panel Power Indicator
MAX POWER (EIAJ)
GENERAL
S/N Ratio: 100dBA
Duo-ß Circuit
Speaker-Level Input
