FS: RS6 OEM Exhaust
Posted: Mon Mar 02, 2009 8:56 pm
by GardinerG
Very good condition. £120 + postage.
You will see that this exhaust comes in 4 pieces plus unions so will fit inside an average saloon/hatchback/estate.
Can be collected from Fleet, Hampshire or possibly from an Audi meet subject to arrangement.
CheeRS!
Grant
Posted: Mon Mar 02, 2009 10:18 pm
by mattsimis
The OEM RS6 exhaust is one piece, is this the Sound Enhanced version?
Is it from an Avant or Saloon and can you provide the measurements roughly, for postage purposes!
thanks
Posted: Mon Mar 02, 2009 10:27 pm
by GardinerG
It was from a 2003 Avant and cut for storage by a previous owner, hence the included unions.
I will check measurements and let you know, but finding enough bubble wrap/cardboard may be an issue!
Posted: Mon Mar 02, 2009 10:29 pm
by mattsimis
Cool, SE or not still interested. Being cut makes it a lot easier to post too!
Posted: Tue Mar 03, 2009 3:45 pm
by GardinerG
Ok, rough size for package: 150cm x 70cm x 20cm, it may be cheaper to send it in 3 parcels. Presumably you need the weight - which I try to get a bit later.
Grant
Posted: Tue Mar 03, 2009 4:33 pm
by marmite
GardinerG wrote:Ok, rough size for package: 150cm x 70cm x 20cm, it may be cheaper to send it in 3 parcels. Presumably you need the weight - which I try to get a bit later.
Grant
try
www.parcel2go.com they are very cheap and is done through DHL I use them all the time.
Posted: Tue Mar 03, 2009 5:53 pm
by mattsimis
marmite wrote:GardinerG wrote:Ok, rough size for package: 150cm x 70cm x 20cm, it may be cheaper to send it in 3 parcels. Presumably you need the weight - which I try to get a bit later.
Grant
try
Not a bad tip, assuming 35kg weight they are coming in at £70 + VAT to Ireland from UK. GardinerG, if you can PM me the approx weight and your address, Ill check out a final shipping quote, I think it all sounds reasonable enough!
Posted: Thu Mar 05, 2009 1:56 pm
by GardinerG
Now sold!
Thanks for the tip Simon!
