RS4 Standard Parts For Sale
Posted: Wed Dec 17, 2003 5:13 pm
by JohnH
Now that Iain is buying my beloved RS4 as it stands I have a lot of standard parts available. The parts have done about 1,000 miles on the car. If you are interested then send me an email:
Standard ECU
Full Exhaust, Middle Section and Downpipes
Full Front and Rear Brakes
Standard Suspension (Springs, Dampers, Anti Roll Bar)
Steering Wheel
Gear Nob
Dump Valves
Gear Linkage
email: john.ghn@btinternet.com
Re: RS4 Standard Parts For Sale
Posted: Wed Dec 17, 2003 8:09 pm
by Carps
Anyone know if the brakes fit an S4, and how different they will be ?
If not I'll give Kim Collins a call tomorrow. If so, then I'm interested
Posted: Thu Dec 18, 2003 11:41 pm
by JohnH
Standard ECU (8D0 907 551 F)
Full Exhaust, Middle Section and Downpipes (SOLD)
Full Front and Rear Brakes (SOLD)
Steering Wheel
Gear Nob
Dump Valves
Gear Linkage
Posted: Fri Dec 19, 2003 8:13 am
by JohnH
Steering Wheel (SOLD)
Gear Nob
Dump Valves
Gear Linkage (SOLD)
Posted: Fri Dec 19, 2003 9:56 am
by Prawn
Hi carps,
The rears will certainly fit, I had some put on mine this week.
If you have the older non vented rear S4 discs as on mine you will also need RS4 handbrake cables as the origionals will not reach the fittings correctly.
Posted: Fri Dec 19, 2003 10:43 am
by johneroberts
Why hasent Iain kept them??????
should of [img]images/graemlins/frown.gif[/img]
jr
Posted: Fri Dec 19, 2003 12:27 pm
by JohnH
Think he loves the car as it is and intends to keep it for a long time so didn't see any reason to have the standard parts
Posted: Fri Dec 19, 2003 4:05 pm
by Iain
I'll never change it back to standard spec...... [img]images/graemlins/smirk.gif[/img]
I dont think I have ever seen a better example of an RS4; all the spare bits that John has available are in the original packaging. A fantastic purchase for anyone considering second hand "new" std rs4 bits.
Posted: Fri Dec 19, 2003 4:10 pm
by jammyhl
Hi,
I'm keen on the suspension bits for my 1998 S4 Avant but AMD are telling me they aren't compatible. Any one else with thoughts/experience about this?
Regards,
Jammy
Posted: Fri Dec 19, 2003 5:53 pm
by Nige_RS4
The RS4 suspension will fit the S4 - there are a number of S4 owners on this forum who have already done this upgrade.
Nige [img]images/graemlins/thumbs.gif[/img]
Posted: Fri Dec 19, 2003 6:54 pm
by DavidR
RS4 suspension bolts straight on, works well (better than old worn out S4 stuff) and does improve the drive. Obviously not as much as, say, an H&R setup, but at a fraction of the price. I found my car a little high at the back with the RS suspension, but I'll be sorting that out soon enough [img]images/graemlins/smile.gif[/img]
Posted: Fri Dec 19, 2003 10:15 pm
by jammyhl
Is there a garage in the SE who will do the fitting for me?
Posted: Fri Dec 19, 2003 10:45 pm
by Carps
Kim Collins QST will probably do the deed for you. [img]images/graemlins/wink.gif[/img]
Cost is likely to be about £250 (£45 per hour), if you can go by the fitting cost of a new suspension kit. They do a four wheel alignment check as part of the fit.
You can get hold of them on 01444 451 542
Posted: Tue Dec 23, 2003 6:57 pm
by JohnH
All I have left for sale are the following so make me an offer and I will consider it.
Gear Nob
Diverter Valves
