RS4 B5 engine bits
andream88
RS4 B5 engine bits
Post by andream88 » Tue May 11, 2010 11:31 pm
bits for sale:
intake manifold
throttle valve
fuel rail
injectors
Y-intake pipe
lower intake pipes (from ICs to turbos)
charge pipes (from Y to turbos)
K04 turbos
2x sets of RS4 Downpipes (one is gutted, the other one is not)
2x sets of RS4 DMFW+RS4 clutch
Everything removed from RS4 B5 AZR engines with 60k to 80k km.
If you're interested in something, just send me a PM.
Cheers,
Andrea
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
andream88
RE: RS4 B5 engine bits
Post by andream88 » Fri May 14, 2010 1:17 pm
BUMP
Rs4 b5 06/2001
andream88
Post by andream88 » Tue May 18, 2010 11:30 pm
OK guys here's a bit of an update:
I have two complete engines to part out.
One is AZR, the other one is ASJ.
- intake manifolds -------both provisionally sold
- y-pipes -------both provisionally sold
- intake pipes and diverter valve hoses -------both provisionally sold
- fuel rails ------ 1x still available 100£
- injectors ------ 6x OEM 100£
- RS4 Airbox+accordion hose+MAF ------1x 80£
- Throttle body boot (metal)+bipipes ------1x 200£
- Throttle valves -------2x 200£
- lower turbo hoses --------1x 40£
- Carbon engine covers --------1x 200£
- RS4 DMFW+clutch --------2x 200£
- driver side RS4 IC+hoses --------100£
- heads 750£
- short block 1800£
- 2x pairs K04 turbos -------both provisionally sold
Regards,
Andrea
Rs4 b5 06/2001
cosgf1
Post by cosgf1 » Wed May 19, 2010 12:43 pm
You have a p.m. :)
