WANTED Various B5 S4 Bits
s4bush
Post by s4bush » Mon Jul 27, 2009 6:37 am
Drivers door carbon trim,
The Fan unit and frame (the one that is located infront and upon the air con rad)
The temp sensor and wiring section that goes from the bottom hose to the rest of the loom by the power steering tank
The wiring section that goes from the air con rad to the rest of the loom by the power steering tank.
The gear stick trim surround and ashtray trim in black or carbon.from a facelift b5 double din dash
S4 front arch linings
S4 under-car splash sheild
Or if someone has etka or elswin, part numbers please.
The car is a pre facelift avant.
Thanks in advance
