Audi 2013 b8 4.2 v8 rs4 engine breaking
Posted: Wed Aug 22, 2018 12:33 pm
by Audilove_a7
Hey guys
I currently have a 2013 b8 rs4 4.2 v8 engine breaking for parts.
The engine has covered 38k with full dealer service history. Unfortunately the oil pump has failed causing damage to the crank so breaking the engine. A list of some parts below but email me if anything else is required.
Some items noted that are available:
*Sump casing
*Engine casings
*Rocker covers bank 1 and 2
*Cylinder heads (these can be sold as seen or reconditioned for an extra cost)
*Crank pulley
*Drive plate/ flywheel (auto)
*coil pack looms bank 1 and 2
*all sensors for engine
*inlet manifolds with fuel rails
*oil filter housing with cap
*complete engine loom
*Engine fuse box, relay box
*flow knock sensors with loom 4x
*pcv breather system with all pipes and breather box
*alloy coolant pipe (rare)
*water pump and drive shaft
*coolant hoses
*evap purge valves bank 1 and 2 plus sensors
*oil pick up pipe, lift pipe to oil pump
* bank 1 and 2 exhaust heat shields
*oil pump drive and gear
*injector loom 2x
*high pressure fuel pumps, roller followers 2x
*fuel injectors 8x
Email me @ hallfm@hotmail.com
I'm located in Scotland in the UK but can discuss shipping etc.
Stephen
