Misc 1.8t big turbo build parts
Posted: Fri Oct 07, 2011 9:29 am
I am splitting a build I was hoping to fit this winter. mainly because I am broke!
aside from the 2.0l 20v stroked AJL block (see other thread for spec)
Many parts transferable between any B5 A4, some specific to the 1.8tqs
I have the following for any B5 -
034 font snub mount and poly bush £40
034 Front subframe bushes £100
034 (1.8t) gearbox mounts £60 (£170 for all of these together)
Bosch 044 Motorsport Rally spec pump + drop in cage and housing £160 (this is the higher flowing rally spec not you bog standard 044 bought from MRC)
Custom TTV 240mm flywheel S4 size with 1.8t bolt pattern £175
Southbend stage 4 S4 clutch (good for 600ft/lbs) £650 (clutch and flywheel together for £750, over £1200 to buy these new)
Tial 44mm Vband Wastegate £200 (with all clamps)
034 gearbox mounts £60 (£170 for all of these together)
AEM AFR gauge with Lamda sensor £120
AEM Trueboost Electronic Boost controller £200
For the 1.8t A4
oversized OEM inlet manifold (2" wider that stock with all stock fittings) £45
Agtronic tubular VBand exhaust manifold (with or without a Tial GT28xx Vband exhaust housing) - £1000 with exhaust housing/coolant/oil lines (I have origianl receipts for over $2000)
Stock VAG Panel Filter £7
Oversized Oil Filter £5 (£7 posted)
VAG Green Top Temp Sensor £5
VAG Water pump belt £5
All parts are in original packaging where appropriate, brand new and unused
Prices include shipping to mainland UK
please email for pics or text
ed(at)ersg(dot)com
07947429616
thanks
For the 1.8t A4
ed(at)ersg(dot)com
07947429616
thanks
