Genuine RS4 B5 2.7T close ratio gearbox
ILikeAv8
Post by ILikeAv8 » Fri Aug 28, 2020 6:08 pm
Standard RS4 B5 gearbox, but closer ratio than S4 gearbox
https://www.ebay.co.uk/itm/373161368410
Needs the first gear repair kit from Audi which is about £100 or replace the 1st gear shaft with the newer 01E shaft.
Other RS4 items for sale under sellers items like higher memory ECU, manifold, injectors.
These parts aren't really that available now and have been sitting at the back of a garage for a decade as I'm into v8's rather than the v6, even though the V6 is more robust, got to go with with V8 passion.
So I'll be happy if someone can use them as they should be on a car not sitting in a garage.
If they sell local collection is preferred north of birmingham but smaller items can be posted internationally, I'm thinking of your shipping costs.
ILikeAv8
Re: Genuine RS4 B5 2.7T close ratio gearbox
Post by ILikeAv8 » Sat Aug 29, 2020 6:32 pm
I've been informed by a member that he spent a lot of money repairing an RS4 gearbox so do some research on parts first. My quotes were from VAGparts a decade ago so prices may have changed.
ILikeAv8
Post by ILikeAv8 » Wed Sep 02, 2020 11:03 am
RS6 exhaust sold and collected thanks.
ILikeAv8
Post by ILikeAv8 » Fri Sep 04, 2020 2:51 pm
All big port V6 heads have been sold and collected now.
I'm slowly adding pictures to eBay
Apparently the A6 strut brace isn't made any more, they only make it for the S4 now. Its in brand new condition never had a chance to fit it before selling the car. Starting bid £130. 👆 Link in the previous message.
https://awe-tuning.co.uk/awe-tuning-dri ... tabiliser/
Lots of unusual A6 C5 circa 1998-2003 parts, a lot in new condition just lying around in the back of the garage for over a decade. Not had a chance to stop and sit down and list them until now that I'm working from home.
Close ratio standard RS4 gearbox needing 1st gear repair + RS4 rear differential looking for offers. Needs first gear repair kit and replace the first gear shaft with the updated one, which you'll find in loads of 01E used diesel gearboxes. Doesn't require strengthening treatment to those shafts as they have a built in torsion shaft.
Loads of 30 valve V6 biturbo parts.
Standard parts and modified parts.
Standard parts - turbo vacuum hoses, wiring loom, crank case, crankshaft, intercoolers etc just ask if you're trying to restore to original spec to increase value.
RS4 original ECU and wiring loom, large memory.
S3 1.8t ECU
Modified parts - large plenum inlet manifold, fully low friction and temperature coated pistons, large throttle body.
ILikeAv8
Post by ILikeAv8 » Wed Sep 09, 2020 8:34 am
A very helpful ebayer reminded me about JHM. They do a variety of repair kits and include a very good instructional video.
RS4 Gearbox and rear diff
https://www.ebay.co.uk/itm/373192414908
Needs this repair kit minimum
https://jhmotorsports.com/01e-6-speed-m ... ollar.html
It's been sat in a dry garage for 15 years so you'll need to decide if anything else needs doing while you have it apart.
ILikeAv8
Reduced price Genuine RS4 B5 2.7T close ratio gearbox
Post by ILikeAv8 » Mon Sep 14, 2020 10:16 pm
Reduced the price on this as I realise the minimum repair kit would be 500USD and needs importing from the US.
https://www.ebay.co.uk/itm/373206677550
Lot of other parts sold now thanks Audi community.
Various other I find interesting will be listed as and when I find them still a lot to go through.
Good to meet and re-engage with enthusiasts that came to pick up parts 👍♻️⚙️
ILikeAv8
Post by ILikeAv8 » Sat Sep 19, 2020 3:21 pm
RS4 gearbox finally sold and to be palleted of. Can start to reclaim some garage space.
Users browsing this forum: No registered users and 93 guests
