B5 C5 2.7 biturbo 30valve parts
ILikeAv8
Post by ILikeAv8 » Tue Aug 18, 2020 6:09 pm
I was collecting these parts to do a 600bhp Passat syncro about a decade ago. I got distracted and the parts are still there in the garage somehow. I'd imagine they'd be interesting for anyone that likes retro Audis. I'm into my v8's now, before they go extinct. I can't imagine getting round to the Passat project in the next decade. Anyway here are some of the parts.
V6 2.7 engine block, I'd begun cutting a cooling channel around the cylinder bores £180
Thick compression head gaskets from 034 motorsport £80
Mechanical lifter kit for the camshafts from 034motorsport £550
Variable cam sprockets £80
Coated standard pistons £170
Coated bearings £60
V6 2.4 block £30
2.4 crankshaft £20
custom made elongated H-Beam rods for 2.4 £400
2.4 heads large port £150 each
2.4 cams long duration £120 each
2.7t heads £120 each
Original inlet manifold RS4 b5 with fuel rail, injectors, pcv spider and larger Porsche cayenne throttle body £500
RS4 b5 ecu and loom £600
RS4 original gearbox with knocking in first gear, (needs the 1st gear upgrade rebuild kit from audi, not included as I don't have it) £600
c5 a6 allroad v6 tdi gearbox, very quick first and second gears with a torsion shaft and high ratio offroad selector £200
6 paddle clutch and lightweight flywheel £400
There's more stuff as well that I can't remember and will add when I go through what's there. I'll add photos when I look.
ILikeAv8
Re: B5 C5 2.7 biturbo 30valve parts
Post by ILikeAv8 » Thu Aug 20, 2020 4:18 pm
Some of the parts, looking in the same condition still. Open to offers any enthusiasts.
With a big enough turbo these used to do over 800bhp? Not bad for a compact engine.
RS4 inlet manifold, fuel rail, injectors
Porsche throttle body
Extended plenum S4 manifold rpm
Extended plenum
RS4 rear diff
RS4 gearbox
RS4 rear diff pn#
2.7 crank shaft
2.7 S4 pistons fully coated top, skirts, under
Users browsing this forum: No registered users and 328 guests
