Page 1 of 2
Original Audi RS4 B9 2020 Carbon Fiber Interior Trim Kit - RHD - UK (matte and glossy)
Posted: Fri Apr 10, 2020 11:03 am
by LittleDevil
Original Audi RS4 B9 2020 Carbon Fiber Interior Trim Kit. Fit to all B9 series. A4/S4, A5/S5 Sportbacc, RS5 Sportback and RS4 Avant! Matte and Glossy Carbon Available.
Price: 1150EUR + shipping + paypal fees
Info: PM or litledevil@gmail.com
Audi RS4 Glossy Carbon Interior Trim Kit
Audi RS4 Matte Carbon Interior Trim Kit
Re: Original Audi RS4 B9 2020 Carbon Fiber Interior Trim Kit - RHD - UK (matte and glossy)
Posted: Thu Apr 16, 2020 1:51 pm
by bobededog1
LittleDevil wrote:Original Audi RS4 B9 2020 Carbon Fiber Interior Trim Kit. Fit to all B9 series. A4/S4, A5/S5 Sportbacc, RS5 Sportback and RS4 Avant! Matte and Glossy Carbon Available.
How easy is it to remove the existing interior trim?
Any pictures Little Devil?
Sent from my SM-N976B using Tapatalk
Posted: Thu Apr 16, 2020 3:53 pm
by LittleDevil
It is 1h job or even less. I will make and post some pictures tomorrow.
Posted: Thu Apr 16, 2020 7:49 pm
by bobededog1
LittleDevil wrote:It is 1h job or even less. I will make and post some pictures tomorrow.
Thank you
Posted: Sat Apr 18, 2020 10:27 am
by mk280483
You have also one for lhd?
Posted: Sat Apr 18, 2020 3:36 pm
by LittleDevil
Yes LHD is also available, both matte and glossy carbon.
I will post all pictures on Monday or Tuesday.
Posted: Tue Apr 21, 2020 12:31 pm
by LittleDevil
Here is picture... RHD matte and glossy carbon, LHD is the same, but I can make pictures too.
Posted: Wed Apr 22, 2020 12:53 pm
by LittleDevil
And two more RS4 B9,5 2020 matte carbon, with and without flash.
Posted: Wed Apr 22, 2020 1:03 pm
by bobededog1
LittleDevil wrote:And two more, with and without flash.
These look very nice, trouble is they look a like a bit an ordeal to remove existing without causing damage.
Has anyone on here got any experience of removing and fitting trims?
Posted: Wed Apr 22, 2020 1:54 pm
by LittleDevil
There is no more than 1 hour to replace all those trims. :wink:
Posted: Thu Apr 23, 2020 12:53 pm
by LittleDevil
Here is quick installation guide:
Tools Needed:
- Socket Screwdriver 8mm
- Torx TX20
- Trim Removal Tool
Dashpanel Small Trim:
Remove fuse panel cover on driver side.
Remove 5 screws with Socket Screwdriver 8mm.
Grab your trim where you see the arrow and pull it out gently.
Use Torx TX20 to remove switch and there are 4 clips which needs to te pressed to remove it. Now install you CF frim the same way.
Dashpanel Long Trim:
3 x Torx TX20 screws needs to be removed. Open glove box and remove then and one on the other side.
Once all 3 screws are remove you just need to pull trim out. Start on passenger side you can us trim removal took or simpy grab it and gently pull it out.
You need to remove AC unit and mileage reset switch. There are 4 x Torx screws on AC unit and numbers of tabs and two tabs on mileage reset switch. Now install you CF frim the same way.
Center Console:
Remove 1 x Torx TX20 screw on the bottom of stowage compartment under rubber...
Use trim removal tool and pull it out on one side and than on the other.
Remove two Torx TX20 screws to remove stowage compartment. Now install you CF frim the same way.
Door trims:
Only trim removal tool is needed for all 4 door. Gentyl access to the tabs behing with removal tool and that's it.
If you have any question feel free to ask. :thumbs:
Ales
Posted: Tue May 05, 2020 3:29 pm
by LittleDevil
2 x Matte Carbon and 2 x Glossy Carbon available for RHD - UK Cars.
Kind Regards
Posted: Mon May 11, 2020 8:32 am
by LittleDevil
Picture from customer, took him 45min for installation...
Posted: Wed Sep 02, 2020 6:39 pm
by LittleDevil
More sets vailable for RS4 and RS5.
Best Regards
Posted: Wed Sep 02, 2020 6:46 pm
by LittleDevil
RS5 Coupe - Glossy Carbon
