New B7 Headlight Mod/Ballast
May fit others, Magneti Marelli OEM
1 307 329 115/8E0 907 391 B
Non Adaptive
Brand new
£95 delivered
Non Adaptive
Brand new
£95 delivered
Re: New B7 Headlight Mod/Ballast
Is it a different ballast for adaptive and non adaptive?
I'm looking for one but have adaptive headlights
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
I’m pretty sure adaptive and non adaptive use different modules but it’s not a subject I know much about TBH
Hopefully someone can give us the answer as I'll take it off your hands if it does work
Anybody help with this one the code on my original ballast is
The part number looks to be 8E0941329A for the adaptive lights on mine.
Just checked on a VCDS scan.
Etka lists the non adaptive as 8E0907391B - https://audi.7zap.com/en/rdw/audi+rs4+a ... 941005/#12
So, unfortunately, it looks like they are different.
Unless one has superseded the other...
Mike
Mike
Thanks for your help. So I'm looking for a 8EO907391A for mines. Do the know the best place to buy them?mikep99 wrote: ↑Thu Mar 19, 2020 10:42 pmThe part number looks to be 8E0941329A for the adaptive lights on mine.
Mike
No idea tbh.
Perhaps try ebay etc.
Its not something I've had to replace on mine (yet!).
Mike
Mike
Just an FYI, the AFS ballast number you’re going to be putting into google, eBay, etc is used across a few models, especially the A3. If you get one that been used on a different model and not the B7, you’ll need to assign it to the B7 A4, before you can adapt it.
It’s not that difficult if you have VCDS but try and do yourself a favour and get one that’s been in a B7 A4, if you go for a used ballast.
Oh and 8EO907391A is the correct part number for AFS ballasts. They have a different connector on the bottom, from the non-AFS ballasts.
Apologies for jacking your for sale thread. Thanks againKenny147 wrote: ↑Fri Mar 20, 2020 3:37 amJust an FYI, the AFS ballast number you’re going to be putting into google, eBay, etc is used across a few models, especially the A3. If you get one that been used on a different model and not the B7, you’ll need to assign it to the B7 A4, before you can adapt it.
