RS6 C5 parts inc headlight, calipers, mirrors, brake hoses, fuel pumps, ABS unit, wheel caps, wood trim, door cards
I have sold my RS6 C5
And as such my collection of parts is no longer required.
Some new, some used, some things mid refurb, some things needing refurb.
I will just list it all and add the photos.
If you want to know more about something just ask, and can work out the postage etc
Edited list:
ABS Controller - not tested, it came from the USA attached to the electronics which is what I needed, note the electronics attached have a broken pin and is just used as a cover.
Fuel pumps - both working fine, I replaced both on my car because I upgraded.
Front brake kit - used for 1 set of pads can be cleaned up - but as I had refurbed the calipers I went new again.
Full set of wood trim - great for wrapping, a couple of fixings damaged see photo. Also the wooded gear knob, which is cracked.
Steering wheel inc airbag
Door cards - not including trim, switches or speakers.
Coolant hose
Electrical plugs
Handbrake
A pair of plugs for the front brakes for when you use pads without a wear sensor (turns the light off).
Edited list:
Coolant hose
Electrical plugs
Handbrake
Used to own an RS6 C5 Avant
Re: RS6 C5 parts inc headlight, calipers, mirrors, brake hoses, fuel pumps, ABS unit, wheel caps, wood trim, door cards
More photos (20 limit per post)
Last one.
I am interested in the nearside headlight, may take other side as well off you? I have a 2003 C5,do you know what year of car these came off, I'm assuming they are the same? How much would postage be and cost for lights?
Headlight and mirror covers SOLD.
Brake hoses and wheel caps SOLD.
Edited the list and the photos.
Any takers before eBay?
Some bits sold, edited again. Link above for some bits on eBay.
Anyone local interested in anything for a few quid before I bin it?
Still got these bits... any takers?
I "May" be interested in the trim if it's silly cheap ? I have wood in mine and would only want this set to play around with carbon skinning.....
Make an offer. Can you collect from Milton Keynes?
Yeah can collect easily enough. I don't even know where to start with an offer.
Just think of the highest amount you would pay, and its quite likely thats going to be the same amount as the lowest I would accept
But somebody must want the door cards surely? Low risk customisation/refurb option if you want to leave your originals (which was my plan).
Pics and price of the front brake kit?
@softishman on IG
Check out my RS4 there!
Users browsing this forum: V!per and 70 guests
