Wanted : B5 (2001) RS4 Front mounted oil cooler
Posted: Tue May 01, 2018 6:42 am
by weta.worker
Hiya, I'm after a replacement front mounted oil cooler for my B5 RS4.
I'm just on the tail end of an engine and gearbox rebuild and the mechanics have found that my oil cooler is missing some thread...
Does anyone have any leads on a replacement unit (2nd hand is fine if in great condition)
John (Wellington, New Zealand)
Re: Wanted : B5 (2001) RS4 Front mounted oil cooler
Posted: Tue May 01, 2018 7:44 am
by dhali
Get a setrab one . It's the same thing . You just have to get someone to weld the the brackets from your original oil cooler onto the setrab one . Plus you can fit stainless steel fittings you will never have the corroded joints issue again .
Posted: Tue May 01, 2018 9:35 am
by weta.worker
dhali wrote: ↑Tue May 01, 2018 7:44 am
Thanks! You wouldn't to happen to have a link to the correct part?
Cheers!
Posted: Tue May 01, 2018 9:53 am
by dhali
https://www.rennsportshop.com/de-fahrze ... ction_ms=1
Double check dimensions on your Oem cooler . And you have to buy the fittings to fit your Oem pipes seperatley .
Posted: Tue May 01, 2018 10:03 am
by weta.worker
cheers!
