For sale: Intake manifold spacers s6-s8
Posted: Sat Jan 14, 2017 11:40 pm
I bought these and was supposed to fit them after a carbon clean but im trading the car in on wednesday to thats not going to happen!
PARTS INCLUDED: The JHM V10 FSI Intake Manifold Spacer Kit will include the following parts:
2x- JHM Intake Spacers (1 for each side of the intake)
2x- OEM Intake gaskets (1 for the each of the top sides of the spacers that mate to the intake manifold.) On lower mileage cars you can reuse the stock gasket between the spacer and the cylinder head. If you're unsure of the condition of your OEM gaskets, select the option below for a second pair of gaskets.
- 12x Stainless steel bolts, that are longer to accommodate the spacer (6 for each side of the intake)
- 12x Washers for the supplied longer bolts (6 for each side of the intake)
-JHM Oil Separator Heater Bypass Kit. This helps keep the intake temperatures even lower and takes very little time (less than 5 minutes) to install with the intake manifold removed. NOTE: Not recommended for extremely cold climates.
Information about them: https://jhmotorsports.com/shop/catalog/ ... 21_360_361
Pictures to follow
Looking for £200 posted to UK.
Dan
Pictures to follow
Dan
