Wanted c7 front number plate plinth
Posted: Thu May 26, 2016 2:03 pm
by Steveo1
Hi folks Ive got a short reg plate to put on my new rs6 and need to cut down the plinth to accommodate it,so if you have one or any other suggestions would be appreciated
Re: Wanted c7 front number plate plinth
Posted: Thu May 26, 2016 6:30 pm
by RS6chris!
I did away with it all together and used existing number plate screw holes.
Posted: Thu May 26, 2016 7:18 pm
by Steveo1
Cheers for that mate
could you tell me how the plinth comes off?
Many thanks
Steve
Posted: Thu May 26, 2016 8:15 pm
by vestax32
I'm interested in this too as will be doing exactly the same when V5 comes back. Does the plinth just clip off with force? RS6chris, are there holes already behind the plinth ready to screw short plate directly to?
Posted: Thu May 26, 2016 8:27 pm
by Trups
vestax32 wrote:I'm interested in this too as will be doing exactly the same when V5 comes back. Does the plinth just clip off with force? RS6chris, are there holes already behind the plinth ready to screw short plate directly to?
They are screwed in. I've done the same with my c6, removed it as that how classba ran it, but I will be getting the smaller one done. My body shop do a good job of it, I could find out how much they charge but you would need to send one to them to mod.
He does it perfect so the oem mounting points still line up centre.
Trups
Posted: Thu May 26, 2016 8:35 pm
by vestax32
Trups wrote:vestax32 wrote:I'm interested in this too as will be doing exactly the same when V5 comes back. Does the plinth just clip off with force? RS6chris, are there holes already behind the plinth ready to screw short plate directly to?
Trups
Ok cheers. I think I actually prefer it without the plinth, so will just screw directly to the grill using existing holes.
Posted: Thu May 26, 2016 9:25 pm
by RS6chris!
Yes
Just remove number plate
Plinth is screwed on
Unscrew and un clip
Already screw holes there which I used for small number plate
Simples.
Posted: Thu May 26, 2016 9:39 pm
by Steveo1
Many thanks
Posted: Tue Feb 27, 2018 7:34 pm
by Yossarian
RS6chris! wrote: βThu May 26, 2016 9:25 pm
Yes
Unscrew and un clip
Simples.
RS6chris can I ask what size/dims your smaller front plate is?
Cheers, Steve
Posted: Tue Feb 27, 2018 11:18 pm
by skirs6
You need one of these
Itβs an Audi part I got from Hong Kong. Fits the same as the OEM plate holder just smaller
Posted: Wed Feb 28, 2018 11:02 am
by Iain
I just cut either edge so the plate was a perfect fit.
