FS: Brand NEW Audi RS4 B7 front Caramic Brake Kit 380 x 38
Revolution
Trader (Expired)
Re: FS: Brand NEW Audi RS4 B7 front Caramic Brake Kit 380 x
Post by Revolution » Wed Dec 17, 2014 11:37 pm
Sorry, daft Geordie humour took hold...
:thumbs:
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
LittleDevil
Trader (Expired)
Post by LittleDevil » Thu Mar 19, 2015 1:44 pm
One more 380mm RS4 B7 or B8 kit available. All installation parts are included.
Kind Regards
RossDagley
Post by RossDagley » Thu Mar 19, 2015 1:58 pm
LittleDevil wrote:One more 380mm RS4 B7 or B8 kit available. All installation parts are included.
Kind Regards
Nothing for C6 RS6?
Previously:
LittleDevil
Trader (Expired)
Post by LittleDevil » Thu Mar 19, 2015 2:00 pm
Kind Regards
Nothing for C6 RS6?
With some adaption you can install RS6 C7 ceramic brakes on C6.
Kind Regards
RossDagley
Post by RossDagley » Thu Mar 19, 2015 2:49 pm
LittleDevil wrote:
Kind Regards
Nothing for C6 RS6?
Kind Regards
Could you be more specific please? What needs to be done, is there a readily available kit for this, and what is the likely cost if so?
Previously:
LittleDevil
Trader (Expired)
Post by LittleDevil » Fri Mar 20, 2015 3:18 pm
Fronts just need spacer between wheel hub and caliper holder + longer bolts for caliper installation, rears more difficult, because custom holder for caliper is needed, because rear is 370mm in diameter.
Ales
Softishman
Re: FS: Brand NEW Audi RS4 B7 front Caramic Brake Kit 380 x 38
Post by Softishman » Sat Jul 29, 2017 2:57 pm
I wonder if you can source custom caliper brackets for an RS4 B7 and cermic brakes from a RS6 c7 370mm with ferrari handbrake calipers aswell? 😇😉
Front (400mm) just needs spacer and center ring to fit..
A longshot but must ask!
@softishman on IG
Check out my RS4 there!
TBRRS4
Post by TBRRS4 » Fri Dec 08, 2017 8:04 pm
Can anyone please tell me what the thickness of the aluminum spacer is? I can't seem to buy just the spacer and I already have the R8 calipers and ceramic rotors. Will have a custom spacer made I guess... Cheers ~
Surrey Sam
Post by Surrey Sam » Fri Dec 08, 2017 8:08 pm
5mm spacer required to get the correct offset. However R8 callipers have no calliper carriers, as they mount direct to the suspension upright. So you'll need to get custom ones made as Audi don't sell them seperately.
TBRRS4
Post by TBRRS4 » Fri Dec 08, 2017 8:19 pm
Thank you Surrey Sam! My R8 calipers already have the mounting brackets attached, so I should be good, no?
Surrey Sam
Post by Surrey Sam » Fri Dec 08, 2017 9:13 pm
I can't answer that as R8s don't have carriers. So no idea what ceramic kit you're trying to fit. If 380mm and the callipers came with carriers they could be from a B7 RS4, B8 RS4/RS5 or S8.
TBRRS4
Post by TBRRS4 » Fri Dec 08, 2017 9:31 pm
My bad! The ceramic calipers are from a RS5, so that explains why they have the mounting brackets already attached. Thx again.
Surrey Sam
Post by Surrey Sam » Fri Dec 08, 2017 9:39 pm
No problem, you're welcome.
BenzV8
Post by BenzV8 » Fri Oct 19, 2018 8:17 pm
Hello,
Where might I be able to source 5 mm spacers for ceramic brake kit on the B7? Also will the spacers increase the tyre track or not and will I then need to install two others on the rear?
Users browsing this forum: Google [Bot] and 88 guests
