For sale: Intake manifold spacers s6-s8
legacydan
Post by legacydan » Sat Jan 14, 2017 11:40 pm
I bought these and was supposed to fit them after a carbon clean but im trading the car in on wednesday to thats not going to happen!
PARTS INCLUDED: The JHM V10 FSI Intake Manifold Spacer Kit will include the following parts:
2x- JHM Intake Spacers (1 for each side of the intake)
2x- OEM Intake gaskets (1 for the each of the top sides of the spacers that mate to the intake manifold.) On lower mileage cars you can reuse the stock gasket between the spacer and the cylinder head. If you're unsure of the condition of your OEM gaskets, select the option below for a second pair of gaskets.
- 12x Stainless steel bolts, that are longer to accommodate the spacer (6 for each side of the intake)
- 12x Washers for the supplied longer bolts (6 for each side of the intake)
-JHM Oil Separator Heater Bypass Kit. This helps keep the intake temperatures even lower and takes very little time (less than 5 minutes) to install with the intake manifold removed. NOTE: Not recommended for extremely cold climates.
Information about them: https://jhmotorsports.com/shop/catalog/ ... 21_360_361
Pictures to follow
Looking for £200 posted to UK.
Dan
legacydan
Re: For sale: Intake manifold spacers s6-s8
Post by legacydan » Sun Jan 22, 2017 9:02 pm
bump, 180 takes them
rs6_sid
Post by rs6_sid » Wed Jan 25, 2017 12:58 am
i would be interested but id need to find out if this fits the 5.0 tfsi engine
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
legacydan
Post by legacydan » Wed Feb 01, 2017 11:24 pm
Sorry for delay in reply. but i believe they only fit the 5.0 s6 or s8 engine which sharre the same intake manifold. The manifold on the 5.0 TFSI has different spacing and shape to the manifold ports i believe
Users browsing this forum: No registered users and 1107 guests
