FS: Genuine Vossen CV1 - 20x10.5 ET30 - SOLD
For Sale: Vossen CV1 in Matte Black with gloss black lip (custom colour)
Bought new Feb 2015; mounted 10.04.15 & removed 22.08.15 (covered approx. 2600 miles); pristine condition . 20"x10.5" ET30; needed 3mm spacers at front to clear RS4 B8 BBK (non-ceramic); these are not included in sale. Centre bore 66.5mm. RRP was £2,200 (+ £200 to refinish with matte black centre & gloss black lip). These are no longer available to buy new.
I understand that these will fit A5 & S5; RS5 will probably have same issues clearing BBK as stated above.
Asking £1100 collected
Note: WHEELS ONLY
I'm based in Wigan.
Thanks for looking
David
Images on RS4 B8
1784
1785
1783
1786
1787
Actual wheels; images taken today
Note: WHEELS ONLY
I'm based in Wigan.
Thanks for looking
David
Images on RS4 B8
1784
1785
1783
1786
1787
B8 RS4 in Daytona Grey
A1 S line Black Edition (Mrs')
Recent Past:
BMW 325i M Sport Coupe (E92), BMW Alpina D3 (E90), A4 DTM Quattro (B7), BMW M3 (E46)
Recent Past:
Re: FS: Genuine Vossen CV1 - 20x10.5 ET30
Images (from internet) of CV1s on Audi RS5, S5 & A4 Allroad...
Recent Past:
Recent Past:
Will these fit r8.
Projex did a set of CV1s for an R8 but, as you can see from this image, the fronts are pretty much flat and I suspect are 9" width whilst the rears have a large concave profile and are probably close to the 10.5" width that I'm selling. I'm no expert, but, unfortunately, I would say that mine are not suitable for the R8Eazyy wrote:Will these fit r8.
Recent Past:
Recent Past:
WILL THEY FIT RS4 B7?
I believe that the following RS4 has the Vossen CV1 19x10 ET36 with 22mm spacers (making ET14). If that is the case, then there should be enough space to fit my 20x10.5 ET27 rims (i.e. including 3mm spacer to clear brakes). My rims would be inset by 7mm compared to the ones in the image.RS04_EBS wrote:WILL THEY FIT RS4 B7?
The big issue will be with the tyres. Minimum recommended is 275/30r20 (and that's even a stretch to some). The standard RS4 B7 set up has 255/35r19 tyres on ET29 rims so the edge of the tread of the 275/30 will sit 12mm closer to the wheel arch. You need to check whether this is possible with your current standard set up. Alternatively you could use a 265/30r20 tyre but this will be a stretch and will probably expose the outer rim edge when fitted. That would mean that the tyre would sit 7mm closer to the arch.
BTW the edge of my rims will poke out a considerable 21mm from the standard.
Its possible and would be extremely aggressive; depends on the look you're after.
If anyone has experience, please chime in.
thanks
david
Source:
http://www.speedhunters.com/2014/08/las ... ever-need/
Recent Past:
Recent Past:
Oops just noticed that the RS4 has -4.0 degrees camber to accommodate the rims so my advice above is probably not valid and my rims would NOT fit the RS4 B7 with standard camber settings.
Sorry!
David
Sorry!
David
Recent Past:
Recent Past:
Further to above; these Vossen CVTs are same spec as mine so would give same aggressive look with, I suspect, plenty of rubbing!
Look good though!
Source:
http://www.luxury4play.com/audi/224082- ... ossen.html
Look good though!
Source:
Recent Past:
Recent Past:
I love these wheels, just a shame they are not 21"
21" rims on an RS4MikeFish wrote:I love these wheels, just a shame they are not 21"
Might be a touch OTT but could be worse...
Recent Past:
Recent Past:
LOL, no for the C7 RS6.
I think they'd still look superb Mike.
20s look just too small on the C7, not helped by having a too high profile.
Shame they don't make them anymore, I don't think they made them in 21" anyway so it would have had to be the 22s which means a new set of tyres to add to the cost too.
Re: FS: Genuine Vossen CV1 - 20x10.5 ET30 Price Reduction
Price reduced to £1100 collected
Concave Heaven
Concave Heaven
Recent Past:
Recent Past:
Will these fit a S4 B8 avant?
Users browsing this forum: No registered users and 46 guests
