RS4 PARTS CLEAROUT..
jimbo1234567
Post by jimbo1234567 » Mon Jul 25, 2011 12:18 pm
ive got too much stuff in the garage so here goes.
s4 engine , complete apart from egt sensors,turbos and tbb. 90k £550
ko4 turbos £600
k04 intake pipes, set of 4 . £175
2.8 n/a inlet cams £50
set of rs4 cams inlets done 110k exhaust out of 2.8 heads so had an easy life £150
rs4 heads, bare castings with valves and springs , no cracks, cleaned and skimmed . £800
avus rs4 £10,000
fdp rs4 gearbox £750
rs4 wheels , round but powder coating flaking£80 each
1 refurbed rs4 wheel.good as new £150
rs4 engine loom, £40
rs4 black leather door cards. £60
mtm v2 cearmic coated rs4 exhaust manifolds £1200
st2 rs6 turbos with mrc intake pipes, refurbed and as new £3300
2.4 heads ported and polished by jnl racing complete with supertech springs and titanium retainers, cams, followers covers etc. heads done 5k ,valve train done 23k £2500
rs4 bottom end , overhauled 5k ago with mrc rods , rehoned bores , new piston rings, new big ends. £1800
prices plus delivery.
Graze
Re: RS4 PARTS CLEAROUT..
Post by Graze » Fri Oct 12, 2012 7:30 am
Jimbo do you still have the door cards
I'm looking for the grab handle shells (if in good nick) to replace mine
Graze
Current
V12 Vantage S
Sold
2007 B7 RS4, Ibis white, 8mm spacers, carbon chin spoiler
2001 B5 RS4, Metallic Black, Neuspeed rear ARB, 275/30/19's + 10mm spacers on B7 RS4 wheels! 034 motor mounts, APR snub mount, JHM shortshifter, 18Z calipers & slotted rotors, custom FBSW
jimbo1234567
Post by jimbo1234567 » Fri Oct 12, 2012 9:16 am
hi , all my parts are b5 rs4 , you have a b7 dont you ? jim :bigwave:
IvorY
Post by IvorY » Fri Nov 30, 2012 5:03 pm
Hey, do you still have the turbo's?
mikeyquattro
Post by mikeyquattro » Fri Nov 30, 2012 6:39 pm
jimbo1234567 wrote:hi , all my parts are b5 rs4 , you have a b7 dont you ? jim :bigwave:
Graze has a B5 too.... :biggrin2:
Tomorrow is another day
jimbo1234567
Post by jimbo1234567 » Thu Dec 06, 2012 10:28 pm
this original ad is ancient, heres my current list of parts for sale. :biggrin2:
propshaft £50
engine loom £150
gear linkage £40
front drive shafts with cv joints £50each
rear drive shafts £50 each
air con rad £30
fan control module £30
wiper arms and blades £10
a/c pipes on engine £35
boot floor securing net £30
mint silver leather interior inc door cards £900
glove box £10
rs4 carbon engine covers £235
oem catback exhaust system £60
full set of shell panels with bumpers and arch liners £2500
front discs calipers ,carriers ,hosesand pads ,mint cond discs £350
load cover £35
cargo net £20
90k rs4 engine longblock with fsh £2000
steering wheel with airbag £100
Wiper linkage and motor £50
Central locking pump £30
Seatbelts set of 4 £80
Pas resevior cover £5
Set of matts, not brilliant £15
Oem rear diff mount £5
Driveshaft heat shields , the pair £20
A/c condensor £15
Horns the pair £10
Rear arb drop links £20
Metal rs4 throttle body boot £75
Aux fan front £20
Aux fan rear £20
Brake servo £20
Brake master cylinder £15
Brake fluid resevior £10
Pedal box £40
Rear top arms £30
Fuel lines( engine bay) £10
Bonnet strut £20
Abs module £150
Oem duall mass flywheel , top notch £50
Airbag module £125
Alloy roof rails £50
Rear lights pair £40
Front abs sensors each £30
Top lambda sensor £20
Lower lambda £20
Clutch slave cylinder £15
4 shocks and springs, rears nearly new £100
6 month old rear shock top mounts £80
rs4 injectors £70
fuel tank complete with pump £150
leather wallet, binder and all books £30
lock set with keys £80
wheel well insert complete £30
bonnet (goodwood) £80
good battery £25
rf4ab
Post by rf4ab » Sun May 05, 2013 12:02 am
Hi
Have you still go the fuel pump?
Thanks in advance
Fred
tsunamirs
Post by tsunamirs » Sun May 05, 2013 5:23 pm
Hallo, front brake kit is original b5 or B7 rs4?
METALLO VELOCE
RS2 I5 B4 2,2 20v turbo avant 315HP
RS4 V6 B5 2,7 30v biturbo 380HP
replica_rs4
Post by replica_rs4 » Thu Aug 08, 2013 1:26 am
Hello, looking for metal throttle body boot and bi pipes that connect to boot.rs 4 b5
Thank you
Serge
V_kgb_way@hotmail.com
dazb5rs4
Post by dazb5rs4 » Mon Aug 04, 2014 9:20 pm
Hi do you still have the RS4 bottom end thanks
jimbo1234567
Post by jimbo1234567 » Thu Aug 07, 2014 11:22 pm
wow this thread is 3 years old. I have been breaking b5 rs4,s for 2 years now so a lot of parts have come and gone.i have a lot of stock so let me know what you need. :nogarors4:
Divine
Post by Divine » Sat Dec 27, 2014 10:03 pm
I know this thread is old but do you have an RS4 glovebox? Thanks
Post by MikeFish » Sun Dec 28, 2014 1:02 am
divine wrote:I know this thread is old but do you have an RS4 glovebox? Thanks
Isn't it the same as a normal A4? Thought there'd be loads on ebay.
Divine
Post by Divine » Tue Dec 30, 2014 9:19 am
It probably is tbf. I will find out. Thanks
jimbo1234567
Post by jimbo1234567 » Fri Jan 02, 2015 11:28 am
yes ive a good one here £35 delivered, the shade of the black plastic can vary and be a blueish colour if a non rs4 part. :nogarors4:
Users browsing this forum: Google [Bot] and 137 guests
