Tailor Made Audi RS4 S4 A4 Weather Shield Outdoor Car Cover 1994-2008 Cost me£540
Reason for sale: I sold the car a while back and this has been sat in my shed, i only got to use it once (pictured) never left it outside only ever fitted when i had cleaned the car and intended to put it away it was undercover in my garage not outside (NEVER PUT IT ON A DIRTY CAR) . I paid £540 for this from Vertar Car Covers its item code is CC-WS-D-GREY
Colur: Grey
Payment: Payment can only be made by Paypal as a gift to avoid charges or cash if you are collecting it.
The Product - Product Features
Covercraft WeatherShield Car Cover (Grey) - Features
Tailor-made to fit your vehicle.
Water Resistant - Water literally runs off this fabric.
Breathable - Heat and condensation under that can build up under the cover can evaporate easily.
Scratch-less - Nextec® technology provides superior protection; tested to 1,000 cycles without scratching.
Superior Dry Time - Because the fabric sheds moisture, shake it and it dries in minutes.
UV Resistant - Special additives prevent UV degradation and protect the vehicle's finish.
Dust Proof - Patented fibre encapsulation process prevents dust from filtering through the fabric.
Compact & Very Light - All this protection in a lightweight package that folds down so compactly you do not lose valuable storage space.
Easy Care - Wash and Dry the cover in a home washing machine.
Double Stitched Seams - Double lapped and stitched for strength and shape retention.
Neoprene Elastic Hems - Sewn into the front and rear of the cover to aid the best fit possible.
Reinforced Grommets - Fitted as standard two reinforced, non-scratch grommets are added to assist with securing the cover with a tie-down cable or for long-term storage
Lock Guard System - To eliminate the opportunist thief from stealing the cover.
Covercraft WeatherShield Car Cover (Grey) - Description
There has never been a car cover Fabric this good! Named the WeatherShield because no other fabric has ever shielded your car from the elements like this one. Using the Nextec® encapsulation technology WeatherShield is the Ultimate Car Cover - providing maximum protection without being bulky, hard to use or difficult to store.
As well as defending against the elements the fabric's effectiveness is also proven in prevention against UV degradation which can harm the pigmentation in paint finishes especially flat colours such as red, white and black where oxidisation is most likely to occur.
For a complete fit the WeatherShield car cover is Tailor Made to your vehicle and is completed with all seams being overlapped and double stitched for durability, with neoprene elastic used in the front and rear hems to help provide that final snug fitting.,
Reinforced, non-scratch, tie down grommets are installed whilst in production to use during extended storage or windy conditions and will not marr or scuff the vehicle in any way.
Should you be looking to disguise or accentuate your vehicle then this is the perfect product.
bargain at £270 delivered
[img][/img]
