KSport 330mm Brake Package
GDS968
Post by GDS968 » Mon Apr 02, 2012 9:59 am
Up for sale is my KSport setup which is just over 2 years old. Have gone back to a refurb set of standard calipers as the car may be up for sale soon!
This setup has been very reliable over the past 2 years. I did have a slight issue with one of the calipers (corrosion under one of the stainless plates the pads sit on) but that was sorted by Apex who sell them and a replacement caliper issued, they said that it had been the first caliper sent back ever!!!
These discs are 330mm and fit under 17inch wheels. Theres still plenty of meat on the discs (31.5mm) on both, new they were 32mm! I had the discs and bells cryo treated by Nitrac Performance before they were fitted and this has made a massive difference to overall wear. They look a bit grubby at the moment but all faces are good and they will NOT need skimming etc, just bolt on and go.
Setup includes lightweight calipers, rotors/aluminium bells, steel caliper brackets, original fitting manual etc. 1 x set of unused KSport Pads (not pictured), 1 x set of EBC yellow stuff pads (used but not pictured) and 1 x set of DS2500 pads (used) but loads of meat left and the ones that were fitted last.
Looking for £560.00 all in and ideally collected.
Will post at cost if required.
GDS968
Re: KSport 330mm Brake Package
Post by GDS968 » Wed Apr 04, 2012 10:22 pm
Sold
